Replacing Supercharger Gasket
Petrucci914
Post by Petrucci914 »
Finally got to it! Was sick of the whistling, idling, and 5psi of boost!Just got the blower off and peeled off the gasket. Could see that air and heat was bypassing the seal, so everything should be fixed after it all gets hooked up. I'll have pictures showing the issue.......nothing like taking those bolts off the head agian. What a PITA!
northvibe
Post by northvibe »
hope it fixes it! cant wait to see pics of what this old gasket looked like....
kevera
Re: Replacing Supercharger Gasket (Petrucci914)
Post by kevera »
What do you think it was,bad gasket or maybe crushed up on install?Hope it sets everything back straight,I know you've had lot's of fun.
Petrucci914
Re: Replacing Supercharger Gasket (kevera)
The old gasket, I believe, was the one taken off the guy I bought the SC'er off of.......so it was a used gasket (stupid on my part). That gasket was flat and thin metal, and was then covered with the Permatex stuff. This new gasket, for an 02 Corolla, was a Fel-Pro one that was already somewhat coated and a bit thicker......I still put on the Permatex stuff. I think one corner was just too flattened originally, or it just couldn't hold the pressure of the air towards the end.
Petrucci914
All done!Seems to run and pull a lot better. Although it just eclipses 5psi.I'll see how the ECU adjusts and maybe the gasket has to form and seat itself a bit. Will monitor and report.Pictures await.
Celtic_Curse
Post by Celtic_Curse »
I hated those manifold bolts. Glad you got pressure now.
2003 Supercharged 5spd Vibe BaseGM Supercharger + TRD ECUMagnaflow Cat Back + DC Sports Header 18" AXIS rimms w/Kumho TiresTop Spoiler + Vis CF Functional Scoop
Lancer
Post by Lancer »
Wanna comeup and do mine? I need to take off my s/c to get to the vvt-i valve. I too have been putting it off. New job, now moving to bigger house has kept me buisy. And I dread those manifold bolts!! Your ecu should adjust and give you more boost. Mine always does that when I reset the ecu. First 2 days are only 5-7 psi. Then after a few days it's back to 9-10 (when it's cooler).
northvibe
Post by northvibe »
dang...i need a boost gaugeadam - glad its helping! I hope you get this thing figured out !
Petrucci914
Re: Replacing Supercharger Gasket (Lancer)
Quote, originally posted by Lancer »Wanna comeup and do mine? I need to take off my s/c to get to the vvt-i valve. I too have been putting it off. New job, now moving to bigger house has kept me buisy. And I dread those manifold bolts!! Your ecu should adjust and give you more boost. Mine always does that when I reset the ecu. First 2 days are only 5-7 psi. Then after a few days it's back to 9-10 (when it's cooler).Ya, brother. Pick a weekend and I'll help you out. Just make sure you have plenty of wrenches, w/ and w/o ratcheting ends and we'll get'er done!
DiveNut
Post by DiveNut »
Glad to hear you may have the low boost situation resloved.
Bare Bones Base, Abyss 2004 Vibe, Debadged, Auto, ABS, GM Performance Supercharger, Injen CAI, 2.3" URD Pulley, Unichip,Tru-Cool Tranny Cooler SOLD
1972 Plymouth Duster 340 (Strip/Street Project)
Petrucci914
Re: Replacing Supercharger Gasket (DiveNut)
Bad gasket!
kevera
Post by kevera »
That's screwed pretty good.I didn't know you re-used the old gasket.I guess that's a lesson for any new s/c owners not to do.Have your boost levels gone up??
Petrucci914
A little over 5psi....but it's running a lot better and has more power. I know my exhaust and header will result in lower psi......I dunno.Any thoughts on that solenoid mod?
kevera
Post by kevera »
It's a gray area for me,I'm not tuned for it.But...when you changed your hoses,the ones that were cracked.Did you use a larger size.Because I did the same,and noticed about 1/2 to a pound difference with same size to larger hose.
Petrucci914
Just one larger hose........from the actuator to the throttle body.When you bypass the solenoid what does it do? Maybe there's leak with the boost gauge.
kevera
Post by kevera »
It spools to full boost right away.I haven't got any leaks,but the hose size seemed to make a difference,weird.
Petrucci914
What average boost do you put out?
kevera
Post by kevera »
Right now with the new header and x-haust,6.5lbs.I still haven't put that pulley on yet.The header dropped my boost levels,which isn't a bad thing.
Petrucci914
I could have an issue my exhaust. I was at a drive-thru the other day and I heard a rattle off the building. I re-used the donut gasket when installing the header, so maybe that's leaking.I suck! haha.
