Base suspension versus GT suspension?
QUIKAG
Post by QUIKAG »
I posted in this forum because of the greater amount of traffic. I have a bid on ebay for some TRD lowering springs. Are the springs in the base model and GT model the same or different? Will I notice a difference with the TRD springs on my Vibe GT? I want a firmer ride, not necessarily lower, though that wouldn't bother especially the 1.25 inch drop as advertised.Also, is there a specific set of TRD springs for the GT or are the TRD springs the same for both base and GT? What about shocks between base and GT? Any links for info?The auction is over in about 6 hours. Any information would be greatly appreciated!
'03 Vibe GT monotone silver/black interior, 17 inch wheels, 6-disc changer, power packageMods: AEM intake, TRD springs, A-spec Strut Bar'01 Corvette Coupe silver/black interior, six-speed, Z51, a few mods, 12.29 at 117.3mph in 1/4 mile on street tires.
NY Pete
Re: Base suspension versus GT suspension? (QUIKAG)
Post by NY Pete »
I believe that the suspensions on the base and GT are identical. The TRD springs are basically rebadged Eibach Pro-kits. You will probably be happy with the ride on the TRD's, but realize 1.25 is not going to look too much different from stock, as you are starting out with nearly 3 inches of fenderwell gap! Pete
'02 Jetta 1.8T Silver Arrow/Black Leathuh - Neuspeed turbo inlet pipe, 17" VW Exor wheels, euro Bora tails, Neuspeed Sofsport Springs, Bilstein HD's, Da'lan hitch'03 20thAE GTI #3494 Imola Yellow/Black Recaros - Omori/AWE boost gauge, HPA Motorsports Short shifter, Neuspeed 28mm rear sway, REVO programming, Neuspeed turbo inlet pipe, FK Badgeless grille, Kamei eyelids and one big fat grin
QUIKAG
Re: Base suspension versus GT suspension? (NY Pete)
Post by QUIKAG »
I'm not too concerned about lowering the ride height too much because of my cold air intake. I don't want a slammed car to injest water at the first sign of a rainstorm. I was happy with some Eibach Pro-Kits on my old Prelude, so I'm sure I'll like them on the Vibe. Thanks!!
QUIKAG
Post by QUIKAG »
Well, I won the auction, I'll tell you how I like my springs when I get them here and installed. Thanks!!
NY Pete
Post by NY Pete »
The install on these cars goes fairly smooth (the front is easier than the back), so just take your time and I'm sure you'll be satisfied with the new stance... oh, and don't forget pics! Pete
QUIKAG
Post by QUIKAG »
You got it! I have a buddy who is very mechanically inclined. All's he normally asks for his services is lunch, so I'll make sure to enlist him to help install the springs and strut bar I won on Ebay.
mu_ohio
Post by mu_ohio »
I just installed mine today and I can tell a big difference. Most is when making a hard 1-2 or 2-3 shift. Before the upgrade, the car would lift a lot in the front compared to the new springs. The same is also true on hard braking. The car doesn't seem to have the same nose dive properties. Not that much of a difference in car height but I do notice as well.
2004 Pontiac GTOPhantom Black w/black leather
QUIKAG
Re: Base suspension versus GT suspension? (mu_ohio)
Post by QUIKAG »
How hard was the install? Any special tools needed? Are the instructions good? My springs are set to arrive via UPS today.
mu_ohio
Post by mu_ohio »
Honestly, I payed to have mine installed. Mine did not come with instructions but basically the short ones go up front and the tall ones are for the back. Just make sure you install them with the wording facing up.
QUIKAG
Post by QUIKAG »
Well, they're installed and they kind of a pain the (removed). Doing it over again, it would take quite a bit less time, but it took a bit over 3 hours with my buddy and myself with my roommate occasionally helping. Finally, with less than 1 MINUTE remaining, I'm torquing down the lug nuts and I break a lug! Ugh, I had thr torque wrench on 85lb/ft as the manual indicates, but it would click and turn a bit more and I would turn, it would click and keep turning, so I kept cranking, finally pop there goes the lug. Try to get that fixed in the next day or two...
Lorin
Post by Lorin »
You're not the first to pop a lug nut. They seem to be pretty fragile at that high torque. I think if I ever do any wheel work, I may be setting it down to perhaps 70 ft-lb, depending on how it "feels".... I know, I know "that may not be safe...." I am sitting here wondering how easy it will be to undo lugs put on that tight with the standard jack kit if I ever experience a flat.
Lorin2003 Pontiac Vibe GT, Neptune-mono, moons & tunes, power package, side impact airbags, rear seat covers, bumper protector, cargo mat.Mods installed: TRD exhaust, TRD stb, Mods removed: TRD CAI - annoyed by CEL
MadBill
Post by MadBill »
Quote> Finally, with less than 1 MINUTE remaining, I'm torquing down the lug nuts and I break a lug! Ugh, I had thr torque wrench on 85lb/ft as the manual indicates, but it would click and turn a bit more and I would turn, it would click and keep turning, so I kept cranking, finally pop there goes the lug. Try to get that fixed in the next day or two...Err.., couple of things, QUIKAG:1. Per page 6-77 of the Vibe Owner's Manual, the torque spec is 76 lb-ft, not 85.2. When my torque wrench clicks, that's when it's time to stop; if I keep pulling, it keeps tightening...3. Even still, it shouldn't break a stud at just over 85; I would expect it would take 100 +.4. You didn't use any lube on the threads or nut seats did you? Lube is a no-no. (P. 5-25), and will give the effect of way too much torque.5. I think our studs are a little on the feeble side; I've heard of a LOT of breakage..
QUIKAG
Re: Base suspension versus GT suspension? (MadBill)
Post by QUIKAG »
Apparently I made several mistakes on this one. Well, the stud is going to be replaced today at the dealer and I'll start using lube and the 76 ft/lb of torque per the manual. I guess I didn't recall correctly the spec as I read it a few months back. Thanks again for the great information!!
MadBill
Post by MadBill »
Hope this isn't too late, but:Sorry, I guess I wasn't as clear as I thought! The manual states that you should NOT use any lube on the wheel nuts.(I've reworded my previous post just to be sure.)
cohocarl
Post by cohocarl »
quote:3. Even still, it shouldn't break a stud at just over 85; I would expect it would take 100 +.All 20 lugs on mine survived 100lb tq by a bonehead at Discount Tire.
QUIKAG
Re: Base suspension versus GT suspension? (cohocarl)
Post by QUIKAG »
I know I overtorqued it. I was using an unfamiliar torque wrench (my buddies) and when it clicked it only clicked once and then continued to turn, so I kept turning...big mistake...Anyway, the dealership fixed the stud and I'm back in business. Concerning the handling differences between the stock springs and the TRD springs, I really don't notice much of a difference at all. I do like the lower stance and I do notice less dive during moderate to heavy braking, acceleration doesn't seem to 'bob' as much either. Overall, it's worth it, but make sure you have someone install the springs for you that knows what they're doing or that you have a lot of free time on your hands. You have to take apart a good portion of the rear trunk area to access the bolts for the rear spring/shocks.Thanks for all the info, guys!!
