Reverse Lights
Envy03
Reverse Lights
Post by Envy03 »
Anyone have both reverse bulbs go out at the same time, pull them out only to see that they are both not blown?Where did you get your replacement bulbs? dealer?
kunkstyle
Re: Reverse Lights (Envy03)
Post by kunkstyle »
Sounds like a bad switch. Although sometimes they can be blown and the filament still looks good.Any parts store should have bulbs. They're not a dealer specific item. The last set I got were from Canadian Tire.
Kunkstyle's Garage:2006 AWD Pontiac VibeInfinity/Rockford/Kenwood Audio, CAI, Cupholder LED's, Keyless Entry Mod2000 Porsche 911 C2Kenwood Audio, Ultimate Cupholders, DRL's, 0-60 in 4.9 seconds.
I thought both of mine were blown, but it was the connector on the transmission that was not seated correctly and had worked itself loose
Herb
Re: Reverse Lights (kunkstyle)
Post by Herb »
Quote, originally posted by kunkstyle »Sounds like a bad switch. Although sometimes they can be blown and the filament still looks good.Any parts store should have bulbs. They're not a dealer specific item. The last set I got were from Canadian Tire.I've had the same thing happen on an older car. There's a switch on the transmission that activates the reverse lights. Replacing this should do the trick
Envy03
Post by Envy03 »
this switch replacement, is it a DIY? if so how would I go about doing it?
