Warm spot on stering wheel cover
rdnzl
Post by rdnzl »
On my 09 I nitice that on the air bag "pouch" or whatever you call it, that is on the steering wheel, there is a spot on the left side that is warm when I drive.Why is that? Is is something to do with the air bag system?
drmc1983
Re: Warm spot on stering wheel cover (rdnzl)
Post by drmc1983 »
I'm not quite sure, but i haven't noticed that on mine yet. On my way to work tomorrow i will check it out.Since we are on the topic of noticing things. Do you have an automatic? If so when you put it in manual does yours automatically start at gear 4 no matter what? I'm not sure if that is a problem or not, but it would seem that it should start at 1 at rest. Instead it is always at 4 unless i change it.
rdnzl
Post by rdnzl »
at rest its 1 IIRC.
nygiantzz1
Re: Warm spot on stering wheel cover (drmc1983)
Post by nygiantzz1 »
Quote, originally posted by drmc1983 »I'm not quite sure, but i haven't noticed that on mine yet. On my way to work tomorrow i will check it out.Since we are on the topic of noticing things. Do you have an automatic? If so when you put it in manual does yours automatically start at gear 4 no matter what? I'm not sure if that is a problem or not, but it would seem that it should start at 1 at rest. Instead it is always at 4 unless i change it. Mine does the same, always defaults to 4.
drmc1983
Re: Warm spot on stering wheel cover (nygiantzz1)
Post by drmc1983 »
Is that something to be concerned about?
cycleb
Post by cycleb »
Were you parked in the sun, or running a heater?
rdnzl
Post by rdnzl »
Driving down the freeway with the AC on. I noticed that just to the right of the radio controls, the "pad" has a warm area.
VforVIBE
Re: (rdnzl)
Post by VforVIBE »
Quote, originally posted by rdnzl »Driving down the freeway with the AC on. I noticed that just to the right of the radio controls, the "pad" has a warm area.Headlights on or off... it just might be the heat from lights of the controls... I'll check mine tomorrow.
rdnzl
Post by rdnzl »
Just DTR lights on.I noticed another small warm spot on the right side of the dash, by the passenger airbag. It must be a sensor or something.
