I've been doing some research and see that the 2AZ-FE engine in the 09 Vibe is similar to the engine in the 05-06 Scion Tc. Im sure there would be some slight modifications to fit correctly, but would all the hardware and placement be similar between the two (i.e., header flanges being similar, engine accessories in the same location)?
2009 Vibe GT, Jet Black Metallic, 5spd ManualThe first four banger I have ever owned
Are the header flanges at least the same. I could fab on up, but almost have the time involved goes into making a header. If I could by one already fabbed up, it would minimize downtime and make the build alot easier. Even doing minor cutting/relocating on a entire kit already built is sometimes easier than starting from scratch
I think it could be donestock scion engine stock vibe engine scion supercharger installed Looks like the battery would need to be turned and some tubes routed but not bad
I would say the flanges are the same,so I think it will bolt up.But,not exactly sure if the length would be the same.The only way you'll really find out is if you try it.
