At least on the pre '09s, what is that third button for? The one below the recirculation button for the A/C? I'm assuming it's an option, but what? My only guess is traction control of some sort....
Quote, originally posted by BlueCrush »Isn't that the "Transformer" button! Just don't press it while you are inside the car, or the transformation will crush you!
Quote, originally posted by NibCrom »Just don't press it while you are inside the car, or the transformation will crush you!And as a cautionary tale:
