Is is possible to switch in a 5 speed manual for my auto?
THE VIBERATOR
Post by THE VIBERATOR »
Hey guys. I've been doing some thinking in the recent months and i've decided to begin my search for a 5 speed manual transmission. The car is in really good shape and i dont want to get rid of it so i've decided that i want to find a new 5 speed manual tranny to switch into my car instead of the current 4 speed auto. First of all is it possible to do?And second of all, where should i look for one?Thanks guys. ANY help is appreciated
2003 Vibe Base - Sold2005 Corolla LE 5 speedcustom short ram air box6k HID kitIn memoriam of the Vibe, may you rest in peace:http://www.cardomain.com/ride/3168634
AKLGT
Post by AKLGT »
anything is possible, however the cost to do a tranny swap is very expensive, so unless the car is entirely paid off, it's better to trade it in for an MT. And why settle for a 5MT? If you're gonna throw around that money, may as well swap a 6MT.you will need a tranny, clutch, wiring, gearbox, ecu and lots of money unless you happen to know how to do it yourself.
AKLGT1998 Subaru 2.5RS
lovemyraffe
Post by lovemyraffe »
Yes it is very possible. The 5 spd manual and the 4 spd auto are very easy to change. You can just bolt it in. There isn't going to be much else to do besides reprogram your ECU. You can not take a tranny from a GT and do that swap. That won't work as easily. If you were to do that, wait until you have a problem with your current tranny. To me it seems pointless to fix something that isn't broken. It will be very very expensive to do. To do a conversion like that would cost about $5000-$5500 at my f-i-l's shop.
Re: (AKLGT)
Quote, originally posted by AKLGT » And why settle for a 5MT? If you're gonna throw around that money, may as well swap a 6MT.well, one reason would be the one your hubby said, which is that in top gear, the 6MT is geared lower, so you'd have to run higher RPMs at the same speed than with a 5MT. All the 6MT does is give you one more intermediate gear, which the GT needs so you can try to stay in lift, but the base 1ZZ doesn't need that.--------------------To swap it you'd need a tranny, w/ clutch, different flywheel, clutch slave cylinder, new brake master cylinder, clutch pedal, new shifter, ECU/PCM, and it looks like you'll also need new drive axles, since the part numbers are different for 5 speed and auto tranny Vibes. You might need to unwire the park/neutral start switch and add a clutch to start switch. As for where to look for one, might be best to find an entire wrecked 5 speed, vibe/matrix so that you'd also have whatever other parts you might discover you need.
AKLGT
Re: (joatmon)
Post by AKLGT »
Quote, originally posted by joatmon »well, one reason would be the one your hubby said, which is that in top gear, the 6MT is geared lower, so you'd have to run higher RPMs at the same speed than with a 5MT. All the 6MT does is give you one more intermediate gear, which the GT needs so you can try to stay in lift, but the base 1ZZ doesn't need that.--------------------To swap it you'd need a tranny, w/ clutch, different flywheel, clutch slave cylinder, new brake master cylinder, clutch pedal, new shifter, ECU/PCM, and it looks like you'll also need new drive axles, since the part numbers are different for 5 speed and auto tranny Vibes. You might need to unwire the park/neutral start switch and add a clutch to start switch. As for where to look for one, might be best to find an entire wrecked 5 speed, vibe/matrix so that you'd also have whatever other parts you might discover you need.Because if you're going to go through all that trouble, you may as well enjoy LIFT. :D
THE VIBERATOR
Re: (AKLGT)
heh that is true. I was just researching my options. The 6MT would be difficult to do, and although i love the sound of lift, i've gotta be realistic. Say my car is worth 9 grand. I can buy a pretty decent car with that money. There is a ton of stuff out there. My friend sold his 2001 celica gt for 10 grand so i'd think my car is around that area as of now. I always keep it in good condition. Online, for a 2003 automatic like mine, in good condition it is worth anywhere between 8 grand and 10 grand. The tranny swap, if i do it, would be well down the road. I just wanted to research to see how much it would cost and if it was tough to do. But it looks like the 5MT just bolts right on. Of course i'd need a bunch of other stuff besides the tranny itself, but that goes without saying.
NibCrom
Re: (THE VIBERATOR)
Post by NibCrom »
I wouldn't do it unless you have lots of extra time, money and aspirin.
Re: (AKLGT)
Quote, originally posted by AKLGT »Because if you're going to go through all that trouble, you may as well enjoy LIFT. :DNow I know you're messing with me, and I did laugh. Add "lift" with a tranny swap
THE VIBERATOR
Re: (joatmon)
haha i wish i had lift
kevera
Re: (THE VIBERATOR)
Post by kevera »
A 6 speed from a 2zz will work.It's been done before,so if you're going to go through all that work,make it worth it.A 6 speed swap may be a winter project for me.
AKLGT
Re: (kevera)
Post by AKLGT »
Quote, originally posted by kevera »A 6 speed from a 2zz will work.It's been done before,so if you're going to go through all that work,make it worth it.A 6 speed swap may be a winter project for me.ORLY????
THE VIBERATOR
Re: (AKLGT)
HAH a 6 speed would be nice. Then i can get that LIFT action. But would i need to change anything else exhaust wise? I'm planning on getting an exhaust anyways, so i guess it doesnt matter. My friend from work is getting a 2009 GT. I was so depressed.....i have a lowly 4spd...
AKLGT
Post by AKLGT »
what year is yours again? and remember, the new 09 GT's aren't anything special, just the same thing as the base models but with a spiffy new badging and you have tiptronic in the auto. Same power and torque as the base models. man, the 03 VGT was the best model year for the GT imo. I do miss mine sometimes, but then I just drive the Sti hatch and remember that the VGT couldn't run 12's.
bull77
Re: (AKLGT)
Post by bull77 »
Quote, originally posted by AKLGT »what year is yours again? and remember, the new 09 GT's aren't anything special, just the same thing as the base models but with a spiffy new badging and you have tiptronic in the auto. Same power and torque as the base models. are you sure?Quote, originally posted by AKLGT »man, the 03 VGT was the best model year for the GT imo. I do miss mine sometimes, but then I just drive the Sti hatch and remember that the VGT couldn't run 12's. what's with all the vibe bashing?
Re: (bull77)
Quote, originally posted by bull77 »are you sure?according to the link micbarric posted in http://forums.genvibe.com/zerothread?id=30857 , The GT comes only with the 2.4L engine, The base has a 1.8L engine standard, optional to get the same 2.4L of the GT. The 1.8 is rated 132 HP, the 2.4 is 158. I think the 09's have better torque, which can come in handy, sometimes more important.Quote, originally posted by bull77 »what's with all the vibe bashing?She does not seem to understand that people perceive posts like that as Vibe bashing. Now this thread will probably devolve into another subarite/antisubarite debacle.and lift comes from the 2ZZ engine, not from any friggin tranny.
THE VIBERATOR
Re: (joatmon)
Ahhh right haha got carried away. I have the 03 auto FWD. So that may be some good news. I believe the GT's have the 2.4L. I dont think its 158 hp however. If it is, then thats just sad. A 2.4L making 158 is slow. It seems they downgrade the GT every year now. Whats up with that?
THE VIBERATOR
Re: (THE VIBERATOR)
I just looked at the Pontiac website. It appears the GT does come with only 158 horse and 162 torque, on a 5 speed manual or auto tranny and a 2.4L engine. No lift
