THe math is that (RPMs /(gear ratio * final drive ratio)) * tire circumference * units conversion factors = vehicle speedWhat this means is that given a fixed tire size and gear ratio, RPMs * some constant = vehicle speed, but your numbers don't support that. Using 65 as the base, you had to increase the RPMs by 500, or 20%, but the vehicle only increased speed by 5 MPH, or 7.7% Those two percentages should be the same, but they are significantly different.That means that something isn't linear or directly proportional like it should be In an automatic tranny car, there is some slippage in the torque converter. If your numbers are accurate, then thats the only thing I can think of to explain the differences in percentages. In a manual transmission there isn't (normally) any slip, and the math works well. I guess that at 70 mph, there is more load, which makes the torque converter slip more. Either that or the tach or speedometer isn't all that accurate.It would be interesting to know how much slip there is. At some point, do a test. Cruising along at some speed, 65, 70, 75, whatever, take your foot off the gas and the RPMs should drop. Before the car starts to slow significantly, get that RPM reading, that should be one end of the slip, where the torque converter is driving the engine. Then floor it, and get the RPM reading before the car starts to accelerate . That would be the other end of the slip, the engine driving the torque converter. The diference in RPMs wil lgive you an indication of how much slip there in the auto tranny. Maybe it will be enough to explain the non-linearity you measured with 65 mph @ 2500 RPM, yet only 70 mph @ 3000 RPMHowever, if you ignore that and use math to start with the 2500 RPM@65 MPH and want to increase tire sizez so that 2500 RPMs gives you 70 MPH, then the dirfference is the difference in speed, about 7.7% The stock tire has a circumference of 78.2 inches, you'd want one 7.7% larger, about 84.2 inches. You can play with the tire size calculator at the miata site to see what percentage differences you can get with different tire sizes from the stock 205/55/16 tire sizeOr, you can use the calculator that goodvibe posted about in the tire calculator sticky in the wheels forum, it's pretty cool, does all the math for you, calculates speed vs RPM in different gears and tires sizes . It does seem to require 5 gears, the base AT has only four, so if you use this linkhttp://
www.car-videos.net/tool...ulate it has the base auto tranny gears loaded, but I set 4th and 5th to the same, otherwise it imagined a higher 5th gear. The gear ratios are easy enough to change, but you can adjust the tire size there and see what the target mph is for a given RPM and tire size.
http://www.sfgate.com/cgi-bin/...1.DTL is a news story of a Californian who tried out the 55 mph technique, the amount of gas saved and the hostility created among Californians
