Fog lights on base 2009 Vibe
SagWhite
Post by SagWhite »
Does anybody know if it's possible to plug easily the OEM fog lights on a 2009 Vibe that does not come with it?Because I read that for the older models the wiring was already there, just have to connect the fog, put a relay in the fuse box and change the wiper arm, and then you're ok, like if it was installed by the manufacturer.I've check on mine and I don't see any wiring near where the fog lights are "installed", and don't see any place to put a relay for that in the fuse box...Thanks!
ned23
Re: Fog lights on base 2009 Vibe (SagWhite)
Post by ned23 »
Depends on how you define "easily" you can buy all the parts and most of the wiring is already there. To do a stock jobg means taking the steering column apart. The OEM parts are about $300.
Old Tele man
Post by Old Tele man »
...search the junk-yards (automotive 'recycling' industry), should be half that cost.
• 2014 Prius 1.8L eCVT
• 2009 Vibe 1.8L 4A
• 2004 Vibe 1.8L 4A
