High, Newbie here Compression question.
st_pinetree
Post by st_pinetree »
Hi folks, I am considering a Vibe GT as my daily driver. I am looking at a really nice used 03 and will be doing a close mechanical check of it this week. I've learned a lot by searching the forum here, but couldn't find the specification for a compression test. Would any of you that have a repair manual be able to look that up for me?
2003 GT-Neptune, Moon & TunesMods: KN drop in, Magnaflow exhaust, dead dash beeper, removed cross bars.ordered: brass shifter bushings, new lift bolts
Celtic_Curse
Post by Celtic_Curse »
I believe its 11.5:1 compression on the GT. Hence why they are some what not boost friendly.
2003 Supercharged 5spd Vibe BaseGM Supercharger + TRD ECUMagnaflow Cat Back + DC Sports Header 18" AXIS rimms w/Kumho TiresTop Spoiler + Vis CF Functional Scoop
Raven
Re: (Celtic_Curse)
Post by Raven »
I think what he's after is the actual compression in PSI to check the condition of the engine.
Re: High, Newbie here Compression question. (st_pinetree)
The third page of the attached PDF says that for the 2ZZ engine in a Vibe GT, the compression should be:Compression:Compression pressure 1,400 kPa (14.3kgf/cm2 203 psi)Minimum pressure 1,000 kPa (10.3 kgf/cm2 145 psi)Difference between each cylinder 110 kPa (1.1kgf/cm2 16 psi)(I assume that "difference between each cylinder" would be a maximum difference, not a required difference)For comparison, and for anyone looking at a non-GT, for the 1ZZ engine, the values areCompressionCompression pressure 1,300 kPa (13.3 kgfVcm2, 189 psi)Minimum pressure 1,000 kPa (10.2 kgfVcm2, 145 psi)Difference between each cylinder 100 kPa (1.0 kgfVcm2, 15 psi)
Attached files service4.pdf (23.2 KB)
st_pinetree
Thanks a bunch. That is exactly what I was looking for. I will be doing the test on Satuday, I'll post the results! Thanks again.
st_pinetree
It came out 210, 206, 218, 207. All above the minimum specs. Looks like I'm a new Vibe GT owner.
WaveAction
Post by WaveAction »
congrats on the purchase, make sure you take pics when you get the GT and welcome to the forums!
