HU with usb port
vibrtor
HU with usb port
Post by vibrtor »
I've been researching aftermarket HU's with front usb port and am finding that the manufacturer states that you should not start the vehicle with the flash drive installed.This means you have to take it out and reinsert it each time you start the car. This seems totally illogical to me. It's like having to remove a cd every time you want to start the car. It follows that it's then going to start at the beginning of the cd/flash drive every time you reinsert it. I'd appreciate feedback on this. Does this concept seem as ridiculous to you as it does to me?
northvibe
Post by northvibe »
i can see this if the HU can use the usb for updating firmware, so if something is plugged in it may search that device to boot from it to update. If something stays plugged in on boot aka car starting and there is no "firmware" update, it could just take a while longer to load the HU OS because its caught searching the usb drive.
Truckin1999
Post by Truckin1999 »
My wifes laptop won't boot up with something plugged into the USB port. Its pretty lame!
-Sean Cummings--Crushed Blue Steel Motorsports-06' GT, Abyss, Leather, M&T, Tint, Roof Spoiler, Magnaflow Cat-Back, K&N Short Ram modified for ram-air, S-Tech's, 18" KV5 Wheels, SLP Ram-Air Hood, paint matched headlights, strut tower brace.Now Making Custom Vibe Sub Enclosures
northvibe
Post by northvibe »
change the bios boot settings.
Raivis
Post by Raivis »
usb port must be different the sd slot. my wifes van always has a sd card in it and never had any problems.
You got owned by a wagon..... Life is a sexually transmitted disease!!! check me out at http://www.myspace.com/raiviskysdad
vibrtor
Re: HU with usb port (vibrtor)
Post by vibrtor »
JVC customer support said starting the car with the flash drive installed may destroy the data (via a voltage spike(?)). I would think, as long as the HU source is not set on USB, there wouldn't be a problem. I never had a problem with my desktop or laptop when the usb port was turned off via "disable removable hardware". The owners manual for Clarion and Panasonic say the same as JVC. So, I suspect it must be a universal requirement for any HU with a usb port.Does anyone out there have one with a usb port? Do you remove the flash drive each time you start your vehicle?
kunkstyle
Post by kunkstyle »
I don't remove mine, haven't had a problem. It's not set to usb when i start the car though.
Kunkstyle's Garage:2006 AWD Pontiac VibeInfinity/Rockford/Kenwood Audio, CAI, Cupholder LED's, Keyless Entry Mod2000 Porsche 911 C2Kenwood Audio, Ultimate Cupholders, DRL's, 0-60 in 4.9 seconds.
vibrtor
Re: HU with usb port (kunkstyle)
Post by vibrtor »
That's what I was hoping to hear. I figured, as long as the radio isn't set to USB when it's started, there's no problem.
briantforce
Re: (Truckin1999)
Post by briantforce »
Quote, originally posted by Truckin1999 »My wifes laptop won't boot up with something plugged into the USB port. Its pretty lame!if you enter the bios or setup menu on startup (most likely hold f12, but look for the option on startup), just go to boot devices and change the order so it checks the internal harddrive before the usb slots
- Brian T Force2003 Vibe GTBlack with gray lower pannelling, 17" alloysPoineer DEH-P6900ub Head UnitSony Xplod 4way / Poineer ts-a1682r 4wayMTX Thunder 4500-4510-04Blaupunkt tha475always 93, always synthetic
kunkstyle
Re: (briantforce)
Post by kunkstyle »
Quote, originally posted by briantforce »if you enter the bios or setup menu on startup (most likely hold f12, but look for the option on startup)Or 'delete'. I find Gateways usually use del for bios settings. Don't know if others do.
