front rotors
nine28
front rotors
Post by nine28 »
is it difficult to replace the front rotors on a 2003 vibe
Kamikaze
Re: front rotors (nine28)
Post by Kamikaze »
Personally I don't think so...I've done quite a few brake jobs, but basically it's as simple as taking off the caliper, replace brake pads pull off old rotors, replace with new... I have a shop w/ hoist and all the tools, so it's probably a little easier. I have not pulled rotors on my vibe (2006) so w/o looking can't tell you exactly how to do it.
scott_h
Post by scott_h »
Very simple - I had my father in-law help out just in case, because I hadn't touched brakes in probably 20 years. As far as the rotors themselves, just take the old off and put the new on. Nothing to it.It did take us forever to get the rotors off though. We were starting to think there was something holding them on (which there is NOT). But they finally came off with lots of pounding, prying and elbow grease.
Scott
I did mine this past weekend, it was pretty easy. You have to take off the caliper (2 bolts) and the pice the caliber bolts into (another two bolts) You may have to beat on the old rotor to break it loose if it is rusted onto the hub, but if you've taken off the piece the caliper bolts onto, then there is a good open space on the back side for beating.Much easier than the last time I replaced a rotor, which was on a full size Dodge truck, the rotor on that was an integral part of the hub and carried the main wheel bearing.
Sublimewind
Post by Sublimewind »
Kamikaze
Re: (Sublimewind)
Post by Kamikaze »
I knew someone did a "how-to", just couldn't remember who... I should have guessed it was you.and Yes.. the search engine is your friend.
Sublimewind
Re: (Kamikaze)
Quote, originally posted by Kamikaze »I knew someone did a "how-to", just couldn't remember who... I should have guessed it was you.and Yes.. the search engine is your friend.I thank you for that comment...
LOUROK
Post by LOUROK »
just hammer the rotors out. Should not be a problem
