Bubble on side wall
Scootman!
Bubble on side wall
Post by Scootman! »
I was driving down a pot hole filled dirt road the other day and when I stopped I noticed that a small bubble (size of a nickel) was on the transition area between the side wall and the tread. Will this cause a blow out for sure or do I have some time to replace the tire?
tnpartsguy
Post by tnpartsguy »
Don't drive on it if you can avoid it. An actual bubble means the tire's skin is damaged internally, and being where it is, it could blow out really easy.
Scootman!
Re: (tnpartsguy)
Post by Scootman! »
Maybe I should have said that it is raised in a half small somewhat like a bubble form..... ....it does not look too terrrible but I guess it's time to replace it then. These tires are only a few months old too, oh well thankfully I get a huge discount on tires.
lovemyraffe
Post by lovemyraffe »
Replace it asap! It will blow out.
Raven
Re: (lovemyraffe)
Post by Raven »
What kind of tires?
Kamikaze
Re: (Raven)
Post by Kamikaze »
It's called a ply-seperation...It could be small... I've seen them where there's multiple little bubbles... but regardless if it's 1 or 10 of them... it means that the integrity of your tire has been compromised and could blow out at any time...
Re: Bubble on side wall (Scootman!)
Had that happen to one of my tires too... got it replaced as soon as I saw that bubble, not something you want to mess around with.
Neptune/primer/rust
'21 Elantra Limited 2.0L/IVT
VIBEwithanO
Post by VIBEwithanO »
Like ColenelPanic I had a bubble myself once (on my last car). Unlike him, I didn't get it changed (I was poor and didn't think it'd be a big deal). Two days later it blew out hard core right as I was getting on the freeway. I'm so glad it did it before, since a blow out at higher speeds is a bad deal. Change is asap.
2006 Stealth AWDInterior Trim PaintBillet GrillFog Covers (MVTG)Rims & Tires (coming soon!)
4X4CHICHI
Re: (VIBEwithanO)
Post by 4X4CHICHI »
I just had to replace a tire that this happened to. It blew out. It was a rear tire though, calm as far as blowouts go.
2004 FUSION ORANGE VIBE GT200 Watt CD & XM radio, Tinted windows17" Black Casino'sSilverstars Head and Fog, Injen C.A.I.http://www.cardomain.com/memberpage/453424
NibCrom
Re: (4X4CHICHI)
Post by NibCrom »
Pop it like a zit, your call will be fine.I'm just kidding, don't listen to me.
Scootman!
Re: (Raven)
Post by Scootman! »
It is a Bridgestone Potenza G-OO9 which I'll probably replace with a Fuzion ZRi or something comparable.
