Vibe 2004 AC compressor relay
ozziegarzon
Post by ozziegarzon »
Does anyone know where the AC compressor relay is located for a 2004 vibeOzzie ...
Re: Vibe 2004 AC compressor relay (ozziegarzon)
welcome to genvibethe ac clutch relay is in the underhood fuse block. It is the one that is farthest to the front and closest to the battery, enigmatically labelled "M/G CLT" on the inside of the cover
ozziegarzon
Re: Vibe 2004 AC compressor relay (joatmon)
Joatmon,Thank you for your help. I'll see if I can test the relay now that you said were to look. Ozzie..
ozziegarzon
I swaped the compressor relay with the horn relay but the compressor clutch still did not engaged. Ozzie ...
