front strut knock
ramenboy...
front strut knock
Post by ramenboy... »
hey guysi know this has been covered somewhere already, did a search and couldnt find the right info, though. anyways, i'm starting to get that periodic knock in the front passenger side when i hit a bump.mav, i remember your mentioning that you experienced that with the smashing pumpkin () and i think you said y ou tightened the bolts and it went away....something like that. i'm gonna try to do this too, but want to use a torque wrench, so as not to strip or snap the bolts. first, whats the lb/ft for the front strut bolts?second, should i put the car up when i do this? or can i loosen/tighten the bolts as the car sits?thanx in advance.
de-badged o4 vibe
o2 triumph speed four
kevera
Re: front strut knock (ramenboy...)
Post by kevera »
Sounds like either loose bolts or a toasted upper strut mount.When you tighten the strut bolts,do it on a level surface.
ramenboy...
Re: front strut knock (kevera)
thanx kevhow many lbs/ft torque? any idea?
de-badged o4 vibe
Mavrik
Post by Mavrik »
tighten the strut nuts and the nut in the center of thr strut. that made the noise in mine go away.
ramenboy...
Re: front strut knock (Mavrik)
Quote, originally posted by Mavrik »tighten the strut nuts and the nut in the center of thr strut. that made the noise in mine go away.thanx mav. did you use a torque wrench...or regular?
de-badged o4 vibe
