Added some tweeters :-)
Renthorin
Post by Renthorin »
And I could not be happier with the sound :-)They are Polk db1000 1" Dome Tweeters and took about 20 minutes a side to do.Thanks to sstress for some helpful info on placement With the 10" sub in the hatch area the sound is really well rounded now.Will
Sublimewind
Re: Added some tweeters :-) (Renthorin)
Post by Sublimewind »
Quote, originally posted by Renthorin »And I could not be happier with the sound :-)They are Polk db1000 1" Dome Tweeters and took about 20 minutes a side to do.Thanks to sstress for some helpful info on placement With the 10" sub in the hatch area the sound is really well rounded now.WillNice Will....!!!! Glad to see you went with the Polks, that make good products... OT, hows the GN runnin?? Had it out yet? (i'm sure you have)..
Kamikaze
Re: Added some tweeters :-) (Sublimewind)
Post by Kamikaze »
pics???
Renthorin
Post by Renthorin »
I will snap a pict when I get home tonight but it won't be very exciting :-)GN has been out twice. Running well but could always be quicker :-)How is the STI?
Sublimewind
Re: (Renthorin)
Quote, originally posted by Renthorin »GN has been out twice. Running well but could always be quicker :-)How is the STI?Faster than the GN.....I keeed I keeed.... All torn down, adding 200lbs of sound deadener and a competition system...
Renthorin
Post by Renthorin »
Why are you making it slower!!! seriously, you need to take it to the track and get some 1/4 mile stats :-)your goal is quicker than 12.2@113 ;-)
Sublimewind
Re: (Renthorin)
Quote, originally posted by Renthorin »Why are you making it slower!!! seriously, you need to take it to the track and get some 1/4 mile stats :-)your goal is quicker than 12.2@113 ;-)She's already fast enough, 200lbs is another passenger...lol... and the improvement in sound and quieting down the interior will be worth it's weight.. 12.2.... childs play.... lol.... No, but seriously, my tranny right now is my weakest link... one missed shift anf it'll grenade.. at my power level... ASAP, i'll be getting an actual 6MT STi tranny and will be much easier to get some decent 1/4's with it... right now, i'm just enjoying it... Not that is't a really "fast" car, but I walked all over a 04' GTO on the highway with it, repetedly..
Renthorin
Post by Renthorin »
Well yeah but an 04 GTO is......(drum roll please) slowwww... You need to run a modified GN against your modified STI ;-) to get a feel for how well it performs.Here is a picture of the installed tweeter on the driver's side. It is very exciting.......not so much....(2mg picture)...my car needs a bath.http://caninesportsrec.com/100_2114.JPG
Sublimewind
Re: (Renthorin)
Quote, originally posted by Renthorin »Well yeah but an 04 GTO is......(drum roll please) slowwww... You need to run a modified GN against your modified STI ;-) to get a feel for how well it performs.Here is a picture of the installed tweeter on the driver's side. It is very exciting.......not so much....(2mg picture)...my car needs a bath.http://caninesportsrec.com/100_2114.JPGWell, one day I WILL run a modded GN... Oh, and just a FYI, the Subie is more of a WRX than it's bigger brother the STi... one day it will grow up, but for now, it's lil'monster.. lol... Was it difficult to get the tweeters in there? Depth wise?
Renthorin
Post by Renthorin »
no problems getting them to fit. Plenty of room behind the mirror pod...cover...thingy.....Per sstress's suggestion I put them in the lower corners so as to avoid the power mirror wiring.2" hole saw...zip zip..in they went.
Sublimewind
Nice.... rock on... !
Kamikaze
Re: (Sublimewind)
Post by Kamikaze »
looks good! nice clean job...
bigbill25
Re: (Kamikaze)
Post by bigbill25 »
Looks good!Was there wiring for the tweeters already there, or did you need to run wire up from the existing speaker? Thanks.--Bill
Renthorin
Post by Renthorin »
I did not find any existing wiring harness for the M/T tweeters so I just ran the wiring off the door speakers.The Polks come with a crossover to protect them and I swear there is 10 feet of wire :-)I trimmed the wire from the tweeter to the crossover and from the crossover to the door speakers so it was a short as possible.Turns out there was an indentation in the door and the crossover fit there perfectly.I had to peel back the plastic sheeting held in place by tar and when I put it back it pinned the crossover in place well.
Sublimewind
Re: (Renthorin)
Quote, originally posted by Renthorin »I did not find any existing wiring harness for the M/T tweeters so I just ran the wiring off the door speakers.The Polks come with a crossover to protect them and I swear there is 10 feet of wire :-)I trimmed the wire from the tweeter to the crossover and from the crossover to the door speakers so it was a short as possible.Turns out there was an indentation in the door and the crossover fit there perfectly.I had to peel back the plastic sheeting held in place by tar and when I put it back it pinned the crossover in place well.You might want to re-think your crossover placement, water and electronics don't mix well, as you fully know... get it on the INSIDE of that water barrier and you will be golden...
Renthorin
Post by Renthorin »
The crossovers are themselves encased in plastic.They are 'mounted' on the inside of the door under plastic so they will remain dry. The window sweeps push any window water down on the back side of where they are mounted.I would have to take the vibe swimming to get them wet :-)
sstress
Post by sstress »
Renthorin, nice install The Polk tweeter package really makes install easy. They really supply everything you need to do a clean job.BTW, when I lived in Pensacola, FL and was running a '99 WS6 (577 lift cam, programming, 3500 converter, 3.73 gears, intake work, etc) I pulled on a modified GN. I expected him to drive around me but instead to both our surprise, the LS1 kept pulling on him hard. But expensive gas, and a bride changed my Firebird into a Vibe. Go figure?The WS6 just before sale:
