Odd sound from dash area
hambox
Post by hambox »
I've done a search, and think it could be the recirculate motor issue that other owner have had, however the sound is different for me:When the vent is on, does not matter if a/c or recirculate is on or off, I hear a clicking sound that is very similar to a cd or dvd player making a ticking sound trying to read an unreadable disc. It is loud enough to be very annoying and distracting, especially when listening for it! The only other thing it does, is when the A/C is turned on it makes this exasperated, escaping air sound. Blows perfectly cold air, so maybe that's just the sound these cars make?Oh, and first post! Too many times first posts are about negative things, but I'm going to be around here for the long haul; many many plans for this car!
Kamikaze
Re: Odd sound from dash area (hambox)
Post by Kamikaze »
Welcome!I know there are people here that have had the same issues, so they will chime in. i haven't so I really havn't researched the problems you are having... Sorry I'm not much help.If you get a chance you should post some pics of the vibe... We love pics!
VibeMike
Post by VibeMike »
I have had a similiar problem that popped up this week. When I turn the key to on, I hear a clicking sound that also is heard when the engine is on. No sound at all when acc. is turned to or when it is totally turned off. The sound is similiar to a clicking of a CD but it goes up and down in volume but has a consistant beat to it and never stops until I turn off the car.Any ideas before I take it to repair shop?
VibeMike
Post by VibeMike »
An update on my odd dashboard sound problem. When I turned on the internal air recirculation button --the sound went away. So the only time it makes this clicking sound would be when the button is disengaged.Hope this helps somebody!
hambox
Post by hambox »
Mine doesn't go away with the recirc, but if I turn the fan speed up to 4 and let it run for a bit and turn it back down - the sound subsides for several seconds until it comes back. A/C is starting to make a gasping air sizzle sound, so I'm beginning to think the Vibe and I are going to have a tussle!
MRCN RCE
Post by MRCN RCE »
yeah this happened to me, and i took it in to the dealer. it's an actuator that's bad. i had mine replaced under warranty. they ordered the part, and it took them less than a day to replace after the part came in
jsimon63
Re: (MRCN RCE)
Post by jsimon63 »
It sounds like the actuator alraight! Try these links on more of the same in the forumshttp://forums.genvibe.com/zerothread?id=4456http://forums.genvibe.com/zerothread?id=24332These should help you understand what is going on! And Welcome aboard!
04 Salsa Monotone base, SUPERCHARGED! Auto trans , 6 disc 200w stereo, Alloys, K&N filter, Moons and Tunes, Silver Stars in both fog and head lights, And now Magnilow Cat back exhaust! 06 Lava Monotone Base Auto trans, 200w single disc XM, On-star Alloys, Moons and Tunes Loaded 96 Dodge Ram 2500 4x4 CTD Built trans #0 fuel plate and secret adjustments!
