DIY Lowering your Vibe.....
Envy03
Post by Envy03 »
Was wondering if it is worth it to spend the money to get it done, $200, or can it be done by semi experienced car people in a day? Truthfully?!?!?!
Kamikaze
Re: DIY Lowering your Vibe..... (Envy03)
Post by Kamikaze »
I have not done my vibe but I've done Civic's, Eclipses, Preludes, Neons... It isn't too hard, but you might need a spring compressor.
WaveAction
Post by WaveAction »
it's pretty easy if you know what to do, but you would definitly need a spring compressor, and airtools if you got any, makes the job much much easier.i usually lower my car at work(dealership) so i got access to hoists and airtools and spring compressors and all, takes me a good hour-1.5 hours to do the full jobi'd say doing it without all the goods i got access too, it'd take maybe 4 hours..a good hour per strut/shock
northvibe
Post by northvibe »
set aside a day to do it and a spring compressor is a must. If you like working on your car do it, otherwise if you got the money and hate working on your car have a shop do it.
Kamikaze
Re: (northvibe)
Post by Kamikaze »
I had my civic done in an hour.It would take me about 2 hours to do the vibe (I wouldn't hurry myself)
northvibe
Re: (Kamikaze)
Post by northvibe »
Quote, originally posted by Kamikaze »I had my civic done in an hour.It would take me about 2 hours to do the vibe (I wouldn't hurry myself)thats if you know what your doing though I think mine took 4-5 maybe, it was the first time I had ever done it so we went slow.
WaveAction
first time i did my sunfire it took a good 3-4 hours..but after that, once i knew exactly what to do and what tools/sizes i needed for everything, can do it within an hour
Envy03
Re: (WaveAction)
Post by Envy03 »
Would you know of a place that I might be able to rent all those types of tools, compressor included?
keithvibe
Re: (Envy03)
Post by keithvibe »
i JUST finished putting coilovers in my AWD vibe took me longer than expected because of the independent rear suspention. I do have air tools but I did everything with hand tools. I did rent the spring compressors to make the job easier.All said and done because I have never done a lowering before on a vibe with the independent rear suspention and the coil overs needed to be modified it took me about 6hrs. Currently the car is at the shop to get a four wheel alinement.Don't worry you photo mongers i will post a thread with photos of before and after.i did a 2inch drop all the way around
Envy03
Re: (keithvibe)
Post by Envy03 »
Now, I like working on the car, but by no means am I what you would call a experienced car guy. Is it still feasible for my self and maybe two other guys to do it? I have a link bookmarked from here with a complete how to on the lowering job. Where did you rent the spring compressor from?
keithvibe
Re: (Envy03)
Post by keithvibe »
I did the job with no help in that amount of time. And like I said I haven't done it before.So with the help of a few others you should have it knocked out in no time flat.I rented my spring compressor from autozone. 40.00 deposit which is refunded to you as long as you return them.I don't know where you could rent them in Canada though
02csnow
Re: (keithvibe)
Post by 02csnow »
Quote, originally posted by keithvibe »i JUST finished putting coilovers in my AWD vibe took me longer than expected because of the independent rear suspention. I do have air tools but I did everything with hand tools. I did rent the spring compressors to make the job easier.All said and done because I have never done a lowering before on a vibe with the independent rear suspention and the coil overs needed to be modified it took me about 6hrs. Currently the car is at the shop to get a four wheel alinement.Don't worry you photo mongers i will post a thread with photos of before and after.i did a 2inch drop all the way around (removed), you finally did it. Took you long enough.I want to see pics NOW.
Bye Bye Vibe.............
WaveAction
Re: (Envy03)
Quote, originally posted by Envy03 »Would you know of a place that I might be able to rent all those types of tools, compressor included?not sure if you got an autoparts store near you..or even napa..possibly canadian tire..but u can rent certain tools like the spring compressor..thats the main thing you really need
Envy03
Post by Envy03 »
Thanks all for your input. Much appreciated!
kevera
Re: (Envy03)
Post by kevera »
Hit a Princess Auto.They have spring compressors for $14.99.That's what I have and used when I did mine.And a 22mm socket for the front bolts.I would also buy 2 camber bolts for the front,1 on either side to get your alignment close.
Kamikaze
Re: (kevera)
Post by Kamikaze »
get a grind wheel and just go to town.. just put the car on jacks, and cut...
