Direct Aux Input for '06
rsaxman
Post by rsaxman »
Anyone have any suggestions for this? The ones that I have found are good through '05 and require a "band" button that the '06 doesn't have + they say specifically that they wont work with just a CD/Aux button. Any thoughts?
02csnow
Re: Direct Aux Input for '06 (rsaxman)
Post by 02csnow »
This is what you want to use with the cd/aux button on a 06.From Pac-audioAB-GM12 with the AUX-BOXoriPAC-OEM
Bye Bye Vibe.............
rsaxman
Re: Direct Aux Input for '06 (02csnow)
Post by rsaxman »
Thanks...have you used it? Do you know if you can still use the built in changer with it?
02csnow
Post by 02csnow »
I have used it and it worked excellent. Not sure what you are referring to with the built in changer.
rsaxman
Post by rsaxman »
I have the factory 6 disc changer in my Vibe. Some of the direct aux solutions that I have seen indicate that you cannot use the CD changer with it because you are essentially replacing the changer with the aux connection.
bigbill25
Post by bigbill25 »
Quote, originally posted by rsaxman »I have the factory 6 disc changer in my Vibe. Some of the direct aux solutions that I have seen indicate that you cannot use the CD changer with it because you are essentially replacing the changer with the aux connection.You want the PAC AAI-GM12. It will allow you to keep the CD changer and give you two aux inputs.http://www.pac-audio.com/produ...Input--Bill
