Any problems with the old non2009 AWD system?Is it viscous-coupled or electronic Haldex?Do you have to change all 4 tires if you get a flat to keep tread thickness the same?Which Vibe years have an AWD option?Thank you in advance.
Quote, originally posted by stock »Any problems with the old non2009 AWD system?Is it viscous-coupled or electronic Haldex?Do you have to change all 4 tires if you get a flat to keep tread thickness the same?Which Vibe years have an AWD option?Thank you in advance.Welcome if I have not Welcomed you already to the Vibedom!!They are Viscous-Coupled I believe!The Rotation Pattern has be debated but the manual states a "simple Front to Back" Directional type rotation. So that the tires do not move from left side to right side or vis-versa. If a flat is had You do not need to replace all 4 tires. I would replace maybe 2, but that would depend on the difference in tread amount between the tires. If its only a couple of 32nds off I wouldnt worry about it if it is several 32nds off then I would replace in pairs.The AWD were produced for '03, '04. '05 and '06. They returned in '09.There are 2 reasons given for the hiadeous. 1. Emissions standards were changing and the AWD version would not comply. 2. Sales.I hope this answeres your questions.
What about 2009 model year with presumptive nonVC electronic Haldex system, need to change just 2 tires? What does manual say for pre 2007 and for 2009?
Quote, originally posted by Digger »I would keep all 4 the same size. If off too much the tire pressure light would kick on. Tire pressure and tread depth are not related.
Quote, originally posted by ragingfish »Tire pressure and tread depth are not related. I believe he was referring to the way the TPMS measures tire pressure. IIRC, it uses the antilock brake sensors to measure rotation speed. If one tire starts to loose air, it will rotate faster than the others due to decreased diameter. A single tire of slightly less diameter due to wear would probably be detected as being low on air due to faster rotation.
