15inches wheels on a 2009 2.4L?
kowell
Post by kowell »
I know the 2009 2.4L Vibe uses 17 inches alloys 5x115 and can be outfited with 205/55R16 wheels and tires for winter but is there a 15 inches tire that be fitted on the model? Wheels and tires would cost a good 250-300$ less than 16 inches.
Raven
Re: 15inches wheels on a 2009 2.4L? (kowell)
Post by Raven »
195/65/15 is a near perfect match for 205/55/16. A lot of Vibers use this size for snow tires.
kowell
Post by kowell »
Will a 15inch wheel be too small for the 2009 2.4L's bigger disk brake system?
Raven
Re: (kowell)
Post by Raven »
It depends on the offset. You will need to know the offset on the new Vibes. Then you can do a search for a vehicle with 15" wheels the same bolt pattern and offset. The older Vibes used a Corolla 15" wheel but they are 5x100 bolt pattern. Of course by using a 15" wheel you will need a taller tire which means poorer handling but smoother ride.
kowell
Post by kowell »
The 2009 2.4L uses a 2007+ camry wheels with 5x114 pattern, thus my uncertainty
