Supercharger grinds
4azdmunky
Supercharger grinds
Post by 4azdmunky »
So i started up the car yesterday and the supercharger sounded like it had rocks in it. I searched and think that it might be the bearings. Anyone know where i can get some technical specifications in .pdf? I'm looking for information that relates to supercharger oil filling. My neighbor told me he saw some smoke coming from my car last week, i'm thinking something leaked, and the oil drained out. Anyone have this problem?
Raven
Re: Supercharger grinds (4azdmunky)
Post by Raven »
Sounds like rebuild time, too late for oil.
northvibe
Post by northvibe »
how many miles are on it?Could be the screws touching each other or the snout needs the new puck thing and oil.
4azdmunky
Re: (northvibe)
Post by 4azdmunky »
It has less than 10000 miles on it since it was installed end of November. What is the puck thing?
4azdmunky
Re: (northvibe)
Post by 4azdmunky »
it does sound like its coming from where the screws are, so about dead center of the SC.How dangerous is it to drive with it like this? should I pull it out immediatly?
northvibe
Post by northvibe »
HA finally found it, here check this thread out.http://www.9thgencorolla.com/f...41602the screws spin so close if something got in there or they arent workign properly they could rub and make noise. if you say the noise is from the DEAD center of the SC then its something to do with the screws and you need to take it off the block and see if something is broken in there.
kevera
Re: (northvibe)
Post by kevera »
It sounds like your coupler is going.It might be a good idea to open her up and check the condition of the oil and the coupler itself.On side note,it's not a tiny bit of chattering when it's cold,and goes away when warm is it.
4azdmunky
Re: (kevera)
Post by 4azdmunky »
Quote, originally posted by kevera »It sounds like your coupler is going.It might be a good idea to open her up and check the condition of the oil and the coupler itself.On side note,it's not a tiny bit of chattering when it's cold,and goes away when warm is it.Not sure, I havn't driven it since it started making noise so it hasn't warmed up. If it goes away when warm, what would it be? And anyone know where to get a SC repaired or where to buy parts for these things?
northvibe
Post by northvibe »
from what i hear Magnuson makes these and they can be contacted for parts and repair.
kevera
Re: (4azdmunky)
Post by kevera »
Judging by your answer,it never sounded like that before.Are you sure it's from the s/c,because when my belt tensioner went I swore something was wrong with the s/c.Just make sure first before you spend your money.Did you see any signs of an oil leak?This place also rebuilds s/c's,and so does magnuson.http://www.psesuperchargers.com/
northvibe
Post by northvibe »
Yeah I agree ^ take off the SC and spin the pulley by hand to see if its the screws making the noise or the snout, but also check around the engine to see if its something else.
4azdmunky
Re: (kevera)
Post by 4azdmunky »
4azdmunky
Re: (northvibe)
Post by 4azdmunky »
Quote, originally posted by northvibe »Yeah I agree ^ take off the SC and spin the pulley by hand to see if its the screws making the noise or the snout, but also check around the engine to see if its something else.oh yeah, when I took the belt off and hand spun the SC it made the same sound. I got in touch with Magnuson today, they do warranty work on the SC's and since its 5 months old, it might be handled under warranty...sweet!
northvibe
Re: (4azdmunky)
Post by northvibe »
Quote, originally posted by 4azdmunky »oh yeah, when I took the belt off and hand spun the SC it made the same sound. I got in touch with Magnuson today, they do warranty work on the SC's and since its 5 months old, it might be handled under warranty...sweet!Bad to hear about the noise..but sounds like the screws are rubbing. BUT sweet to hear its only 5months old and maybe covered! It should be I would think if its that young a sc and you bought it new.
4azdmunky
Re: (northvibe)
Post by 4azdmunky »
It was bought in November brand new in a sealed box, installed in the beginning of December by a local Toyota shop. The only thing I can think of is that because it is installed on a 05, and I'm running water injection, and the hydrogen cell, that the warranty might not be honored.
northvibe
Post by northvibe »
if you can make your car look stock.....with the sc I would recommend it. They may frown upon tho mods and say that caused it. Where does your water injection inject to? cai or into the SC itself?
4azdmunky
Re: (northvibe)
Post by 4azdmunky »
Quote, originally posted by northvibe »if you can make your car look stock.....with the sc I would recommend it. They may frown upon tho mods and say that caused it. Where does your water injection inject to? cai or into the SC itself?its mounted to the CAI. I'm assuming that I'll need to take the SC off and mail it in for repair.
northvibe
Post by northvibe »
depends if you take it to toyota/gm to get looked at or are sending the SC in to toyota or magnuson. If you take it to toyota/gm i would recommend installing the stock air box, otherwise they could blame your cai, as the instructions say to not use the cai, only the stock air box.
DiveNut
Re: (northvibe)
Post by DiveNut »
X1
Bare Bones Base, Abyss 2004 Vibe, Debadged, Auto, ABS, GM Performance Supercharger, Injen CAI, 2.3" URD Pulley, Unichip,Tru-Cool Tranny Cooler SOLD
1972 Plymouth Duster 340 (Strip/Street Project)
Petrucci914
Re: (4azdmunky)
Post by Petrucci914 »
I dunno. Mine would always make some mechanical noise because, well, it is a mechanical unit. No major grinding or anything, just the sounds of gears turning and whatnot.
kevera
Re: (Petrucci914)
Post by kevera »
His coupler is done,but the good thing is we will experience the same in the future-wuhoo!But the new style coupler lasts longer than the original ones in ours.
Petrucci914
Re: (kevera)
Don't remind me. I'll cry.
4azdmunky
Re: (northvibe)
Post by 4azdmunky »
