It blew last night on the way home but Ididn't realize it until late last night when I let the dogs out and the front eld was leaning to the drivers side. Still driveable for my 2 minute commute each way for work but not much more than that. I'll have to pick up a set of replacement KYB GR2's, ASAP!
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
Go for the Tokicos. If the car is leaning, you may have a broken spring or other problem. My left front strut was totally gone for about a month and it never leaned a bit.
I have seen plenty of blown struts, but none have caused the car to lean. Not saying it couldn't happen, but would be a bit unusual if that was the cause.
'04 Frosty GT <---Click here!Tein S-Tech springs; Tokico HP struts;Progress rear sway bar; DC Sports strut tower bar;Scion TC wheels; K&N Typhoon intake;GG Racing ground wires; JAW voltage stabilizer;FilterMAG SS-250; Militec-1; Sirius Satellite Radio
Tokico's will not work on the AWD, well maybe the fronts. My only option is the KYB GR2's for all 4, which is fine since I am only dropped 1". I had been wanting to replace them all soon anyway. A little sooner than I wanted though.Hmmm...strange that others who have had blownstruts did not lean. I guess it would make sense that it should not since the spring is what is supporting the weight. I had it confirmed this afternoon at the dealer who gave me an estimate to replace it. I laughed, turned and left.
My Fleet:
Quote, originally posted by BlueCrush »It blew last night on the way home but Ididn't realize it until late last night when I let the dogs out and the front eld was leaning to the drivers side. Still driveable for my 2 minute commute each way for work but not much more than that. I'll have to pick up a set of replacement KYB GR2's, ASAP!Perfect time to upgrade your OEM cut springs to some nice lowering springs.. HAHAHA JK...
Quote, originally posted by ramenboy... »hey brianso were you right? dead strut?Yup. Good guess.Quote, originally posted by keithvibe »Perfect time to upgrade your OEM cut springs to some nice lowering springs.. HAHAHA JK... Stop teasing!
My Fleet:
Brian, when I replaced mine I went throw http://www.neverenoughauto.com. They have some great deals. Its not that bad of a job just get a good spring compress and some air tool will also help. Good luck. My car never did the gangster lean ether.
RFP1 17x8 , AFE Cold Air Intake, Helix Power Tower Plus, Eibach Sportline Springs with Tokico Blues, Progress sway bar, Alutec OEM Sized Lightened Crank Pulley full custom Magnaflow 2.5 header back exhaust and B&M tranny cooler E/S inserts Unichip.
