http://www.imgburn.com/Quote, originally posted by imgburn »ImgBurn is a lightweight CD / DVD / HD DVD / Blu-ray burning application that everyone should have in their toolkit!It has several 'Modes', each one for performing a different task: * Read - Read a disc to an image file * Build - Create an image file from files on your computer or network - or you can write the files directly to a disc * Write - Write an image file to a disc * Verify - Check a disc is 100% readable. Optionally, you can also have ImgBurn compare it against a given image file to ensure the actual data is correct * Discovery - Put your drive / media to the test! Used in combination with DVDInfoPro, you can check the quality of the burns your drive is producing
