seafoam?
Twizted-Vibe
seafoam?
Post by Twizted-Vibe »
i just bought a can of seafoam to clean out my engine. ive used this on other cars easily and got awsome results. Right now my gas milage iss 260-300 to a tank which is terrible. i figured this may jelp some and also free up some power. On other cars i just leave the motor on and slowly pour it in the throttle body till i start seein smoke from the exhaust then leave it sit.When i tried it on this car, i cant get the car to stay running without the intake. when i remove the intake, the car stalls!Has nayone else used this? how you do it?
2003 GT: Body Kit - 19" Rims - Lowered - 12000K HID's - Neons - Custom fiberglass - Custom System - Many other mods! View my Cardomain for many more mods/Pics http://www.cardomain.com/ride/2995381
Twizted-Vibe
Re: seafoam? (Twizted-Vibe)
nvm.........got it!
KEYTECHNIQUES
Post by KEYTECHNIQUES »
Whats better then Seafoam is the GM top cylinder cleaner.
djb383
Post by djb383 »
Seafoam is good stuff.................just pour it into the tank and go.
ProtonXX
Re: seafoam? (djb383)
Post by ProtonXX »
1Injector cleaner kinda has the same effect as seafoam when i poured it in my cylinders directly
djb383
Post by djb383 »
Remember, whatever you pour directly into the intake will not also clean the injectors. The cleaning solution must flow through the injector(s) in order to clean them.
1zzfe_808
Post by 1zzfe_808 »
so how exactly do you "pour" it into the intake?
djb383
Re: (1zzfe_808)
Post by djb383 »
I believe cleaners are usually "poured" into carbureted engines, down the carb. On EFI engines, the cleaner can be drawn/sucked into the intake thru the brake booster vacuum hose. Again, this method will not clean the injectors on EFI..........adding the cleaner to the fuel tank will.
