Wet Floor: HELP!
msmyer
Wet Floor: HELP!
Post by msmyer »
Water is getting into the passenger side floor of my car. Front and back. It's been wet for 2 months now. I took it to my local auto shop and they thought it might have been the sunroof but after looking at it was not. Any thoughts? I see a few other people have had this problem...
‘03 Vibe with 317k and still going.............................
Other Mods: Sony X-Plod Headunit & Reflective White GVC decalMy Car at Cardomain.com... http://www.cardomain.com/id/msmyer
Sublimewind
Re: Wet Floor: HELP! (msmyer)
Post by Sublimewind »
The AC drain line... should go through the firewall in the passenger area... it's prolly wet in back due to water running past the center divider.. I'm rather sure it's been covered here many times... Whatever you do, when you can, take off the door sill pplates and get the carpet up and get it dried out...!! ASAP...
hskater26
Re: Wet Floor: HELP! (Sublimewind)
Post by hskater26 »
i had this problem too i just had to connect the two drain piped up in the top left corner of my passenger floor and wire tire them together to make sure they dont come undone again
-2003 Base Vibe-2002 Ducati ST2
zionzr2
Post by zionzr2 »
also make sure there is not a clog in the line.
