I'm going to install a power lock/keyless entry system on my wife's 2000 Plymouth Neon (currently has no power locks) I'm going to use a kit found at JC Whitney http://www.jcwhitney.com/autop...90855Since I'm only going to be using this for keyless entry (No trunk release, no alarm, and no "panic alarm") it looks like the only wires I need from the 16 pin connector are the: White (+12V or (-) Parking light output (connect to switched +12 wire at back of parking light switch or back of light) Red (+12V) Power output (Connect to battery positive terminal) Yellow (Ignition switched "on" and "Start +12V) - The diagram shows this wire being connected to the fuse box, just before the ignition switch, (So do I splice into the ignition wire at the fuse box?) Black - Ground The six wires from the door lock harness are: Violet - (Connect to +12V Constant) (Where would I connect this to?) Brown/Black - Ground Blue/Black - Door unlock - connect to actuator Green/Black - Door Lock - connect to actuator White/Black - Ground Violet/Black - (Connect to +12V Constant) again, where to? Any thoughts? Thanks
2015 Kia Sorento 32,000 miles, 2010 Kia Sportage LX, 68,000 miles
Quote, originally posted by AZViking »I'm assuming any wire in the kit that requires +12 constant means I can attach it anywhere my multimeter reads +12V with the key off.Thats correct. You could attach it directly to the battery if you wanted to.As for the rest, sorry that I can't be of help. But good luck though!
Thanks, that's what I thought. I installed an aftermarked CD player in that car in 2005, but those connections were pretty easy to do. I've installed CB radios in my parents' vehicles in the past, but I probably didn't do that safely (I'd wedge the wire into a fuse (Dome light for example, and ground the radio to a screw in the passenger compartment). Never started any fires, but probably not the smartest way to go. (About 13-15 years ago)
