Hey everyone!Two years ago I bought a '03 Vibe (base) and used it without problems. Now I must receive permission of national TUV (the government agency, that inspects the cars), which follows the standards of The United Nations Economic Commission for Europe (UNECE or ECE).European directive requires that headlights must be approved to an ECE Regulation and marked uppercase "E" in a circle. It means that device (headlights) ECE low beams are characterized by a distinct horizontal "cutoff" line at the top of the beam. Below the line is bright, and above is dark. On the side of the beam facing away from oncoming traffic (right in right-traffic countries, left in left-traffic countries), this cutoff sweeps or steps upward to direct light to road signs and pedestrians (look to attachment). Under US SAE directives (as I understand) low beams may have or may not have a cutoff, and if a cutoff is present, it may be of two different general types: VOR and VOL, which is conceptually similar to the ECE beam in that the cutoff is located at the top of the left side of the beam and aimed slightly below horizontal.Headlights of my Vibe has devices, that marked as SAE HRA15PP2 00. Glasses is denoted STANLEY 01-13 R (L on left) DOT HB2 VOL.Left headlamp of my Vibe produces beam “__/†(with an “elbowâ€) but right headlamp beam has no “elbowâ€: “___†.Why beam of headlights of my Vibe are different? How to aim (refit) right headlight?Thank you.
