FM Transmitters and the stock deck from an 08 Vibe
The Doughboy
Post by The Doughboy »
I'm stillusing the deck that came with my 08 Vibe but I'm having a lot of problems with my FM Transmitter, I find that instead of playing what I'm transmitting it like to receive everyone else's iPods and Sirius radios instead. I never had this issue in my old car, or my wife's or any other car I've been in, just the Vibe.Anyone have an experience dealing with this?
The DoughboyBlack 2008 Pontiac VibeSun Roof7 Monsoon SpeakersPreferred Equipment Package
lovemyraffe
Re: FM Transmitters and the stock deck from an 08 Vibe (The Doughboy)
Post by lovemyraffe »
Welcome to the forums. I use an FM transmitter all the time and never had this issue. Sometimes I will get a signal from a local radio station if it is set too close.
kunkstyle
Re: FM Transmitters and the stock deck from an 08 Vibe (lovemyraffe)
Post by kunkstyle »
Yeah - It seems that every other car I passed I picked up their feed. I ended up buying and FM modulator to eliminate the problem.
Kunkstyle's Garage:2006 AWD Pontiac VibeInfinity/Rockford/Kenwood Audio, CAI, Cupholder LED's, Keyless Entry Mod2000 Porsche 911 C2Kenwood Audio, Ultimate Cupholders, DRL's, 0-60 in 4.9 seconds.
bull77
Post by bull77 »
I don't seem to have an issue with our ipod transmitter. What type of FM transmitter are you using?
northvibe
Post by northvibe »
the itrip worked great on my car, it even had me enter my zip code and find me the best stations to use for fm transmitting. EDIT:HA found it!!!http://stationfinder.griffintechnology.com/now you can see which stations you should use!
The Doughboy
Its the Griffin iTrip I have and the interference isn't from radio stations, its from other people with XMs or iTrips. It seems like as soon as I get on the highway I'm listening to someone else's Howard Stern or Desi music.Well I'm looking at the Sony Xplod cdxgt420ip, anyone know of any thing I should look for when it comes to the vibe and the Sonys
silvrhawk7
Post by silvrhawk7 »
There are a lot of different factors involved with the fm transmitters, for instance i had a big problem with the newer sirius units because the signal seems weak from the transmitter, once i installed the FM relay that ties into the antenna port in the HU 99% of the problems went away. however i suffer the interference problem in my girlfriends caravan because i have not installed the relay yet. I also live in south florida and there seems to be a radio station on every frequency nowadays or interference from other equipment.I also do think that there may be some electronic interference in the vibe/matrix as well because I didnt truly have this problem in my previous vehicle (2000 Chevy S-10)
In Memory, taken too early in a rear end collision
Sunrise: June 2006, Sunset: Jan 2015 :cry:
Miles 129,000
2006 Silver Mono, Base 4-Speed auto.
In Memory of Pontiac Motor Division 1926-2010
In Memory of the Pontiac Vibe 2002-2009
aquamarine
Re: (The Doughboy)
Post by aquamarine »
I ''had'' the iTrip. The only way it would NOT give me interference here in Canada is if I had it sitting on my damn lap the entire time. Even then, if I was turning a corner and my body was in the wrong position, I had nothing but static. I went through SIX of them before I gave up.
Raven
Re: (aquamarine)
Post by Raven »
iTrip works for me.
tribalman
Post by tribalman »
i had the itrip for my nano when i had the stock head unit. i got nothing but static unless the ipod was sitting on the dash. if i adjusted my steering at all it went flying. since then i've upgraded my HU and sound system. i really reccomend using a direct connection to plug your ipod. not one that uses the headphone jack, one that uses the ipod jack. i've used one of those in my friends cars, doesn't give a full surround sound setup. a few songs i have will do that where they "travel" around to the different speakers, it's not as good unless you use the ipod jack.another benifit of using the ipod port, it charges it too!<<a bit of an audophile.
None. Vibe is gone.
