some reviews i have foundhttp://
www.motortrend.com/road...vibe/"The AWD model is a boon in the Snow Belt, but performance is blunted by a combination of the lower-powered engine and a standard automatic transmission.The choicest Vibe is the base model, fitted with a sweet-shifting five-speed manual and that willing, if underpowered, 130-hp engine. It handles just as well as the GT, requires less shifting, and when fitted with the standard StabiliTrak system is just as safe in most conditions as the all-wheel-drive model."
http://www.edmunds.com/pontiac/vibe/review.html http://www.canadiandriver.com/...d.htm"That brings us to the Vibe AWD. The all wheel drive platform operates as a front wheel drive, with rear wheel assist. The engine is de-tuned slightly to 123 horsepower and comes only with an automatic transmission, but this is a fun car to drive. Priced slightly lower than the Vibe GT, at $26,150, the Vibe AWD again comes loaded with equipment. The passenger front seat folds flat so an 8-foot ladder can be carried on the passenger side. An in-dash 115 volt AC outlet enabled us to recharge laptop and digital camera batteries on the go. Cargo hooks were abundant, and the roof rack has several different crossbar options to carry anything from bikes to canoes. Designed for the active set, the Vibe has a 1500 lb towing capacity, just right for a personal water craft or sailboat. Inside, passengers sit a little higher, almost SUV style. The front bucket seats provided excellent comfort during a long day's drive. Fit and finish of the interior was excellent and the control layout was easy to use. Our Vibe AWD was equipped with the optional DVD-based navigation system, a first to my knowledge in this price range. Using a 5.8 inch touch screen in the centre of the dash, the system took a little experimenting to set up, but worked fine in populated areas. Unfortunately, a large part of Canada in still not mapped, so the system's practicality is limited for most of us. On the road, the Vibe is very civilized. On slippery, snow packed roads, the handling was balanced and predictable. The steering is solid, but could use more feedback to the driver. The all wheel drive system worked perfectly and kept us on the road several times. It's operation is almost imperceptible to the driver, and the traction was always there when needed. The automatic transmission was well suited to the torque of the engine, and I never felt like I needed another gear. The engine cruises smoothly and quietly, and the only time I wished for a little more power was when passing at highway speeds. ABS stopped the car in a straight line and allowed steering control on the slippery Northern Ontario roads I was driving on. Overall, the Vibe AWD provided comfortable, secure, and stable transportation, with versatile features and unique styling. For those of you in the know, the Vibe is a joint venture between General Motors and Toyota. Toyota's versionn is called the Matrix, and I priced slightly lower than the Vibe, but does not come will as much standard equipment. When similarly equipped, price is comparable. I would put my money on the bolder Vibe styling. For "Vibrant" online information, check out
http://www.yourvibe.com and
http://www.drivethevibe.com " im still looking for more info...
