AWD Donuts in the snow!!! (Two total)
Whelan
Post by Whelan »
Hey all, got some snow today in CT. Went to the beach to play really quick. I'm goin out with my bud later to get some better video from outside. But for now, enjoy. And for all the FWD'ers out there, feel free to kneel and pray during this video, LOL!Check the second video, better quality with my digi cam setup on a stool I brought down. Good one in the beginning and right after the Jeep leaves. http://youtube.com/watch?v=hEaBmco8O9E http://youtube.com/watch?v=44Vhuuaklnk
2012 GLI Autobahn 6MT
keithvibe
Re: AWD Donuts in the snow!!! (Whelan)
Post by keithvibe »
just remember not to keep going in one direction... to possibly prevent letting your oil pump suck nothing but air
coldmm803
Post by coldmm803 »
cool. i second what keith said, dont end up like this guyhttp://forums.genvibe.com/zerothread?id=31214
Kamikaze
Re: (coldmm803)
Post by Kamikaze »
My Man Whelan!!!!All I could do was laugh...I like the wreath!
lovemyraffe
Re: (coldmm803)
Post by lovemyraffe »
I should go do donuts again. I did some on my little excursion I took the other day, but no place to put the camera to take video. http://forums.genvibe.com/zerothread?id=31232
Whelan
Re: (lovemyraffe)
Post by Whelan »
Is it possible to screw up your wheel balancing by doing this. I only ask because driving today on the highway there was a shimmy at 50 and anything about 60 the car was just wobbling like crazy. I pulled over to check it out. All the wheels are torque'd properly (had my TW in the car, double checked), the alignment is fine and the car does not pull. A brief inspection underside showed nothing broken or loose.I am wondering if even if your alignment is good and your wheels torqued, if the tires not being in balance can cause such a shimmy/wobble. I was doing those donuts last night so it's why I ask before dropping it to get some work done.
drunkenmaxx
Re: (Whelan)
Post by drunkenmaxx »
my theory would be snow somewhere in or on your rims. it's throwing off the balance.
Whelan
Re: (drunkenmaxx)
Post by Whelan »
The rims looked clean, I though snow in the tires but doesn't seem to be enough to cause this. Unless cause the tread is so new that the snow is really packed into it.
drunkenmaxx
Re: (Whelan)
keep in mind, that tiny little slider is what's used to balance most wheels, so it doesn't take much to throw it off.
Whelan
Re: (drunkenmaxx)
Post by Whelan »
I may run out for lunch and get them balance, can't hurt and if it works then suhweet!I really think its the balance cause at low speeds its fine but high speeds are what shakes like crazy.
Sublimewind
Re: (Whelan)
Post by Sublimewind »
Quote, originally posted by Whelan »I may run out for lunch and get them balance, can't hurt and if it works then suhweet!I really think its the balance cause at low speeds its fine but high speeds are what shakes like crazy.Dude, this happens to me ALLLLLL the time, go to the local spray away and clean out the INSIDE of your wheels... That is where the problem lies, trust me... you drift to the left and the right side wheel fills with snow, drift to the right and the left wheel fills... you'll see...
BlueCrush
Post by BlueCrush »
A couple of them looked good, but it mostly looked like you wre driving in circles. lol.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
Whelan
Re: AWD Donuts in the snow!!! (BlueCrush)
Post by Whelan »
Yeah it was kinda hard as the area was small and I didn't want to hit a curb. When it snows again Sunday I may try to get a better one, I didn't wanna push it either, that whole oil pump engine blown thing has me freaked. Although I'm not pushing it near as hard as that kid was. But I did get one or two good ones, especially at the end after the Jeep passed me.I'm heading to the spray shop during lunch, Gonna get the $5 wash see what happens.
drunkenmaxx
<<waiting to do the childish "i told you so">>
Sublimewind
Quote, originally posted by Whelan »Yeah it was kinda hard as the area was small and I didn't want to hit a curb. When it snows again Sunday I may try to get a better one, I didn't wanna push it either, that whole oil pump engine blown thing has me freaked. Although I'm not pushing it near as hard as that kid was. But I did get one or two good ones, especially at the end after the Jeep passed me.I'm heading to the spray shop during lunch, Gonna get the $5 wash see what happens. NOOOOOOOO, your gonna have to get OUT and put the sprayer into any open areas of the wheels and clean the inside out... the drive through isn't going to fix it...
Whelan
Re: (drunkenmaxx)
Post by Whelan »
Quote, originally posted by drunkenmaxx »<<waiting to do the childish "i told you so">>Commence with the childishness.Just went for a ride, got her up to 50 before I got to the wash, seemed ok. So I pulled in, had a smoke, checked the wheels, they seemed clean, got the rest of the sluch from the well. Then took her on the highway quick. 60,70, 80, not a problem! Guess being in the garage at work where its 46 degrees helps.
drunkenmaxx
Re: (Whelan)
<<dancing around, clapping hands and laughing>>
Whelan
Re: (drunkenmaxx)
Post by Whelan »
This is the first car I've owned that has alloy wheels so I attribute some of it to that, all the other ones were Steelies and I never did donuts in them. So the snow must not have been packed like it was on these. Oh well, lesson learned!
drunkenmaxx
Re: (Whelan)
i learned this problem whenever i got stuck in the mud: http://forums.genvibe.com/zerothread?id=15048
kevera
Re: (drunkenmaxx)
Post by kevera »
Trix AWD=Slow
Sublimewind
Re: (kevera)
Quote, originally posted by kevera »Trix/Vibe=Slow Fisked for jou
kevera
Re: (Sublimewind)
Post by kevera »
Quote, originally posted by Sublimewind »Fisked for jouAhahahaha,not like this
keithvibe
Re: (kevera)
Post by keithvibe »
Quote, originally posted by kevera »Trix AWD=Slow thanks for pointing out what we already know...
drunkenmaxx
hey, it's ok kevera, my damn near stock 3400 station wagon would give you and your SC a decent race. (a guy on youtube ran a 15.7 in a stock maxx 3.5)
kevera
Re: (drunkenmaxx)
Post by kevera »
Quote, originally posted by drunkenmaxx »hey, it's ok kevera, my damn near stock 3400 station wagon would give you and your SC a decent race. (a guy on youtube ran a 15.7 in a stock maxx 3.5)I'll follow Sublime's lead on this one and say.....meh.
Sublimewind
Re: (kevera)
Quote, originally posted by kevera »I'll follow Sublime's lead on this one and say.....meh.Yeah, those were my edits, so I wouldn't end up on the outside looking in.....
keithvibe
Re: (Sublimewind)
Post by keithvibe »
Quote, originally posted by Sublimewind »Yeah, those were my edits, so I wouldn't end up on the outside looking in..... HAHAHA the got to you.... bad boy...
mistertwo
Post by mistertwo »
after watching that video you made me feel like i drive my car waaaay too hard.i will take vids next time we get a good snow... lol
wyatt89
Post by wyatt89 »
lol, i cant keep my eyes off the wreath :D and as for the wheels, it happened to me when i was driving back from wyoming to texas and it was from a bunch of snow in my wheels/wells and just kicked it off and off i went. mine wobbled like crazy at about 55mph...
'04 lava GTSRI, Progress rear sway bar, Infinity reference backs, components in the front, Infinity Kappa 124.7w sub, Alphasonik 600rms@2ohms for the sub, alpine head unit, worst paint ever!
kevera
Re: (wyatt89)
Post by kevera »
Second video is way better.Haha,the wreath is too cool,me likes.
drunkenmaxx
Re: (kevera)
it's ok kevera, drunkengirlfriend calls my maxx my grandpa car. take pride in the fact that your car looks way cooler than mine.
AKLGT
Re: (drunkenmaxx)
Post by AKLGT »
Quote, originally posted by drunkenmaxx »it's ok kevera, drunkengirlfriend calls my maxx my grandpa car. take pride in the fact that your car looks way cooler than mine.but i bet you can speed and drive around with your dark tint, exhaust and never have the cops look twice at you!
AKLGT1998 Subaru 2.5RS
Kamikaze
Re: (AKLGT)
Post by Kamikaze »
Quote, originally posted by Whelan »This is the first car I've owned that has alloy wheels so I attribute some of it to that, all the other ones were Steelies and I never did donuts in them. So the snow must not have been packed like it was on these. Oh well, lesson learned!Wait till the tires start leaking on you each winter... that's always fun...Something about allow wheels after a few years have a tendency to leak around the bead of the tire... We run into this ALL the time... also the whole out of balance thing... quite common, people always think there's something wrong with the car, when all it is, is a little snow... just .25 ounces can give your tire a shake due to out of balance...
