Fixing Old Engine
ProtonXX
Fixing Old Engine
Post by ProtonXX »
Is it possible to upgrade to a lightweight flywheel on a automatic?Light weight pistons & Parts...where where :DExhaust rattles after I put it back together. Its between the header/midpipe.Why
Sublimewind
Re: Fixing Old Engine (ProtonXX)
Post by Sublimewind »
Quote, originally posted by ProtonXX »Is it possible to upgrade to a lightweight flywheel on a automatic?Light weight pistons & Parts...where where :DExhaust rattles after I put it back together. Its between the header/midpipe.Why No flywheel on an auto... you are thinking torque converter, which in essence is bolted to the "flywheel" as in a large round steel plate with gear teath cut on the outside, but no mating surface for the clutch... Lightweight pistons and such.... for what, it's a Vibe it was never ment for speed... They ARE out there... http://monkeywrenchracing.com/....htmlThe rattle is prolly a lose heat shield....
Petrucci914
Re: Fixing Old Engine (Sublimewind)
Post by Petrucci914 »
Quote, originally posted by Sublimewind »Lightweight pistons and such.... for what, it's a Vibe it was never ment for speed... Don't listen to him. He's a Subie Fanboy .
Petrucci914
Re: Fixing Old Engine (Petrucci914)
LevelTen does the most Tranny work for our Vibe. MWR also has a Torque Converter replacement.
