Help! Intake Air Temperature Sensor
lovemyraffe
Post by lovemyraffe »
Help! I can't find the IAT sensor. Can anyone help me out?
kevera
Re: Help! Intake Air Temperature Sensor (lovemyraffe)
Post by kevera »
It's in the Maf sensor assembly.It's the yellowish brown probe thingy.
lovemyraffe
Re: Help! Intake Air Temperature Sensor (kevera)
Damn, that's what I was afraid of. You don't know how to take it out do you?
kevera
Post by kevera »
It's one unit,I don't think you can seperate it.Why is your's toasted?
lovemyraffe
I have a stupid code, basically if I can figure out how, I can get away with only doing the IAT, and not the MAF.
kevera
Post by kevera »
Did you try cleaning it yet?What code are you getting?
lovemyraffe
I cleaned it. I will probably have to replace it. But hey, after 46k this is the first thing gone wrong.
kevera
Post by kevera »
They are like $150 for the whole MAF assembly.They are sensitive so disconnect the battery when you fiddle with it.
lovemyraffe
Thanks for your input. I finally broke down and called the dealer, there is no IAT. It is part of the MAF and no other way to do it.
vibegtcouple
Post by vibegtcouple »
if you have a kunkles auto parts up there there the sensor cheaper then the dealer if not junk yard any toyta with are motor is the same
