Transmission Cooler
quicksilver
Transmission Cooler
Post by quicksilver »
Anyone have any advice on where to shop for one of these for a 2004 2WD Vibe?Also, maybe some tips on installation?Thanks!
northvibe
Post by northvibe »
i got mine from summit racing.
Re: Transmission Cooler (quicksilver)
search is your friend.start at http://forums.genvibe.com/zerothread?id=23452 and see where that takes you
quicksilver
Re: Transmission Cooler (joatmon)
Yes, I already checked out that post, and the limited others, thank you though.
02csnow
Post by 02csnow »
You could always check Ebay.Tip- Watch out for the tranny fluid and save every last drop
Bye Bye Vibe.............
kevera
Re: Transmission Cooler (02csnow)
Post by kevera »
Ebay or summit racing are good places.If you work fast,you only drink a little.
djb383
Re: Transmission Cooler (kevera)
Post by djb383 »
Yep, less than 1/2 qt., IIRC. I bought a qt. at the Toyota dealer before I started.
ajflan
Post by ajflan »
Ok I hope this is not a stupid question, but what is the point of a tranny cooler on a car that is making 130hp? (I hope that there is a good reason because I'm running out of things to do...)
February 08' VOTM Check out my Band! http://www.facebook.com/pages/...67945
02csnow
Re: (ajflan)
Post by 02csnow »
A tranny cooler is mainly for a vehicle that has a SC or Turbo, due to all the force and high temps in the tranny. But can also be used on a stock engine if the driver is heavy on it or does alot of highway miles.
ajflan
Re: (02csnow)
Post by ajflan »
Wouldn't highway miles be easier on the trans because it is not shifting as much?
blue_can
Re: (ajflan)
Post by blue_can »
In general you need a tranny cooler if the impellor in the torque converter is turning much faster than the turbine. In this situation a lot of the engine’s output power is dissipated in the fluid and it really heats up. The most extreme condition is when doing a stall test on the transmission – you cannot do that for more than about 5 secs at a time. In normal use you can heat up the fluid by doing full throttle starts, towing or driving up steep hills. Once the TCC has applied there should be much less heat generated in the fluidUnless you do these things or live in a very hot climate a cooler should not be necessary. You can test how hot the transmission gets by using a temp measuring strip on the oil pan. It will record the highest temp reached by the transmission. You get them from most transmission parts stores for a few $.
'07 Vibe
blue_can
Re: (ajflan)
Post by blue_can »
Quote, originally posted by ajflan »Wouldn't highway miles be easier on the trans because it is not shifting as much? Yes, the TCC should normally be applied on the highway so the coupling should be mechanical at that point and so there should be much less heat generated.
'07 Vibe
AKLGT
Post by AKLGT »
Hayden tranny coolers. universal and can be found on ebay for about $50 shipped.
AKLGT1998 Subaru 2.5RS
quicksilver
Sweet, that sounds affordable, easy to install eh? Btw, I'm looking at transmission coolers because I've been towing a good deal of weight lately and I want to protect my Vibe as much as I can I went from a V8 4x4 Jeep Grand Cherokee Limited to the Vibe, and I'm impressed with how much more I like this vehicle
AKLGT
Post by AKLGT »
you will never go wrong with a tranny cooler! and yes, very easy to install.
Lancer
Re: (AKLGT)
Post by Lancer »
Quote, originally posted by AKLGT »Hayden tranny coolers. universal and can be found on ebay for about $50 shipped. Got mine at Advanced Auto for $30. No shipping costs! But total for bigger zip ties, tranny fluid, and some other stuff (tools I didn't have) was around $50.
zionzr2
Re: (Lancer)
Post by zionzr2 »
I have seen tranny coolers avaliable for sale at U-Hual. I dont know how much or if they are any good, but they do sell them.
AKLGT
Post by AKLGT »
there are two types of tranny coolers. you want the serpentine one (i believe that's what it's called).
