Has anyone had to get shims to align the rear axle?
duck3
Post by duck3 »
I have 89,000 miles on my '03 Vibe GT and my driver side tire is starting to wear unevenly. Firestone tells me that its due to the rear-alignment of the car, but its not adjustable. Has anyone else out there had this problem. Firestone said I needed to get shims so that I could adjust the rear alignment. Anyone.....Bueller....ANyone?
northvibe
Post by northvibe »
just get your car aligned and tires balanced at a reputable shop. should be less than 100 bucks. after my accident my alignment was off, so that was covered under the cost of the fix but i had uneven wear on the tires between the accident and fix.
duck3
Re: (northvibe)
Post by duck3 »
It was aligned. On the vibe though...the front is the only thing that is adjustable... the rear alignment is not adjustable. I've rotated and balanced the tires every 8-10,000 miles and have had the alignment checked 2-3X since I've had it. No accidents....so I shouldn't have this problem...but it does have almost 90,000 miles on it...so has anyone been unable to have their rear alighment fixed?
kevera
Re: (duck3)
Post by kevera »
Yeah,I got those disks for my rears,but I'm dropped a couple of inches.They are cheap on ebay and shouldn't be a problem to install.I can't say it's normal for a stock Vibe,but if that's what it takes,then get them.
duck3
Re: (kevera)
Post by duck3 »
I got 3 shims placed on the rear driver side and she's running purdy again...of course to check that out, I had to go on a 500 mile Road trip to make sure it didn't become unstable aboe 60, so of course I had to go 115 for a couple legs of the trip!
