plugging laptop into 115vac dash outlet
tahoejeff
Post by tahoejeff »
i'm taking a trip tomorrow, and want to plug my Dell laptop into my dash plug outlet. will this be a problem? has anyone else done this?i asked this on a diff forum, and one answer worries me:If the laptop has a switching power supply it may not play well with a basic inverter. I toasted a couple of BellSouth supplied 150 watt inverters with the 90 watt power supply for an Itronix Go-Book before I figured out what I was doing wrong.
I plugged mine in to that without a problem.Also my gateway worked well with it.Just check the wattage rating on the dell power supply, because i know my friend's dell was like 110W and it was too much for that supply, so it would pop the internal breaker until he unplugged it.
prathman
Re: plugging laptop into 115vac dash outlet (tahoejeff)
Post by prathman »
No problems with our laptop power supplies (Dell and Toshiba), but, as ragingfish mentioned, check the wattage or current requirement on your power supply. We did have to use a 2-prong to 3-prong adapter to plug in the laptop power supplies.
northvibe
Post by northvibe »
Three of my Apple powerbooks ran fine off of it, my IBM works... all my ipods...cell phone chargers...mmm just dont run a hair dryer and you'll be fine
Quote, originally posted by tahoejeff » I toasted a couple of BellSouth supplied 150 watt inverters with the 90 watt power supply for an Itronix Go-Book before I figured out what I was doing wrong.Try it in the Vibe and see. I have hooked up things that drew more than the VIbe's inverter could handle, and it just shut off. Took off the load and it worked again (for loads within it's capacity). Perhaps the inverter in the Vibe has better overload protection than the inverters BellSouth supplied
psiu
Post by psiu »
I had no problem with my Compaq--had to use a 3 prong adapter is all.
sstress
Re: (psiu)
Post by sstress »
For long trips... I plug a power strip into mine and lay it on the floor. I cut the 3rd prong off and works great.
tnpartsguy
Post by tnpartsguy »
I do turn my brightness level down when using my laptop in the car to help not overload the system. I carry a grounding adapter in the car at all times to make sure stuff can get plugged in, the angle is all wrong for most cords.
AKLGT
Post by AKLGT »
on our road trip from Ontario, Canada to Anchorage, AK back in May 05, i used the plug for my laptop and it worked just fine.
AKLGT1998 Subaru 2.5RS
Herb
Re: (psiu)
Post by Herb »
Quote, originally posted by psiu »I had no problem with my Compaq--had to use a 3 prong adapter is all.Apparently 3 prong adapters are not legal for use or sale in Canada so we'll have to come up with something else.http://www.gov.ns.ca/enla/elec...s.asp
Striider
Re: (Herb)
Post by Striider »
Here, get a cheap grounding strip and use these to cut the grounding prong off the end.
Neouka
Re: (Herb)
Post by Neouka »
I saw 3 prong "cheaters" for sale in a local dollar store, actually.They have the Chateau brand name on them, but yes, they're incredibly illegal here. I don't know how places get them.
03 Abyss Base, not 5 .. 6spd!2012 Focus soon...
wyatt89
Post by wyatt89 »
i made toast in my car to see if it would work...and it did :D im sure your lappy will be fine...
'04 lava GTSRI, Progress rear sway bar, Infinity reference backs, components in the front, Infinity Kappa 124.7w sub, Alphasonik 600rms@2ohms for the sub, alpine head unit, worst paint ever!
TraySeeLea
Post by TraySeeLea »
mmMMm toast with peanut butter~!
Quote, originally posted by 4X4CHICHI »Oh the power of a pretty blonde...lol
zionzr2
Post by zionzr2 »
On long trips there is always a laptop plugged in mine no problems at all. simply use the 2 to 3 prong adapter.
ramenboy...
Post by ramenboy... »
one of the few times i've need to run the ibook in the vibe, it had to be charged. it was fine, but the charger is bulky and had to be constantly pressed into the socket to make the connection.you'll be fine
de-badged o4 vibe
o2 triumph speed four
kunkstyle
Re: (ramenboy...)
Post by kunkstyle »
Quote, originally posted by ramenboy... »but the charger is bulky and had to be constantly pressed into the socket to make the connection.I've got the same problem with my iPod - a little 3" extension cord worked wonders.
Kunkstyle's Garage:2006 AWD Pontiac VibeInfinity/Rockford/Kenwood Audio, CAI, Cupholder LED's, Keyless Entry Mod2000 Porsche 911 C2Kenwood Audio, Ultimate Cupholders, DRL's, 0-60 in 4.9 seconds.
tahoejeff
Post by tahoejeff »
thank you for all the replies and suggestions. now how do i convince my wife she has to have a laptop sitting on her lap when we take trips?she 'tolerated' it while we were taking backroads through the north woods, but...
Herb
Re: (Neouka)
Post by Herb »
Quote, originally posted by Neouka »I saw 3 prong "cheaters" for sale in a local dollar store, actually.They have the Chateau brand name on them, but yes, they're incredibly illegal here. I don't know how places get them.I hadn't thought about dollar stores. They bring in all sorts of odd things too.I went the eBay routehttp://cgi.ebay.com/ws/eBayISA...h=020I just hope they make it past the boarder
Mr. Joe
Post by Mr. Joe »
I've considered taking the hardware out of my 300w power inverter and replacing the inverter in my vue with it.
2007 Frosty Pontiac Vibe, picked it up 6-01-071480 milesLife is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming..."WOW! What a ride!"
