Cooling Fan Problem
gsorge3155
Cooling Fan Problem
Post by gsorge3155 »
I have a 2003 Vibe and am having a sporatic problem with the car starting. It apppears to be related to the engine temperature, ie it starts when the engine is cold-say over night. But won't restart after driving for a few minutes or more.The engine does not crank, the battery is fully charged. It appears to be a switch or relay.I notice that the fan motor comes on when the car is running and stops when I turn the car off.I know there are 2 fan realys and they are different. One is black one is brown. I know the black one is ok because I swapped it with the horn. There isn't another brown one to swap and the part is $45.00Does anyone have a wiring diagram that would help me jump the relay to test?Any ideas or similar problems.Thanks
