Thinking about buying??
Bocaj77
Post by Bocaj77 »
I have been looking at a 2003 XRS with 70,000 miles on it. Wondering how they hold up around this mileage & up. Anything major I should know about?
northvibe
Post by northvibe »
looking at a matrix! The 2zz engine if taken care of prior should have no issue lasting over 200k. The main issues are the clutch and if the TSB's have all been taken care of. Otherwise just have your mechanic take a quick peak at it, mine charges 100 for this once over. Then they can find any issues and give you a recommendation for a purchase or not.
jake75
Re: Thinking about buying?? (Bocaj77)
Post by jake75 »
Did you ever translate miles into time? 70,000 miles @ 45 mph = 1,556 hours = 64.8 days of running. 200,000 miles @465 mph = 4,444 hrs = 185 days of running. So if you drove even the best auto engine for 24 hours a day it would last only 6 months and you'd have to change the oil very 5 days. Doesn't seem like that is very durable. I am guessing a refrigerator compressor runs 12 hours a day and they typically last 15 years. A 36,000 mile engine warranty = 800 hours running time @ 45mph. If a car company expresed their engine warranty as 800 hours running time who would buy?
prathman
Re: Thinking about buying?? (jake75)
Post by prathman »
Quote, originally posted by jake75 »Did you ever translate miles into time? 70,000 miles @ 45 mph = 1,556 hours = 64.8 days of running. 200,000 miles @45 mph = 4,444 hrs = 185 days of running. So if you drove even the best auto engine for 24 hours a day it would last only 6 months and you'd have to change the oil very 5 days.I'd expect a good engine that's kept running at moderate levels to last considerably longer in total running time than typical car use with all the cold starts and varying loads. Oil change intervals could also probably be extended well past 5000 miles when operated that way without contamination of the oil due to condensation when cooling and incomplete combustion at startup. But the figure of 800 hours of operation is pretty consistent with typical small aircraft engines which have TBOs (time before overhaul) of about 1000 hours.I agree with northvibe that the main issue I'd look for would be the clutch which seems to fail prematurely in many VibeGT/MatrixXRS cars.
Atomic
Post by Atomic »
Quote, originally posted by jake75 »Did you ever translate miles into time? 70,000 miles @ 45 mph = 1,556 hours = 64.8 days of running. 200,000 miles @465 mph = 4,444 hrs = 185 days of running. Holy crap, what have you got in your Vibe that makes it go 465MPH?!? and I thought I drove fast.
05 Base Vibe, Abyss (also known as Black to un-Vibers)Auto, Power Pkg, 16" alu, 20% tint all around, Black powder coated roof rails (the anodizing didn't last in the sun)Member of S.A.V.E. (Secret Association of Vibe Enthusisasts)
northvibe
Post by northvibe »
a 2003 with only 70k is low miles
jake75
Re: (northvibe)
Post by jake75 »
1. Good catch - typo - I meant to repeat 45 mph2. My 2003 bought 1-27-03 has 27,800 miles -THAT'S low miles! 70,000 in 5 years is 14,000 a year. Not unusual - perhaps typical, but I don't think it is low. I wonder what an average miles per year would be - leases used to be 12,000 miles. Lately I have seen a lot of them advertised at 10,000 miles - probably a sucker bet - keeps the payment low but hits you with a steep over miles fee at end. A lot cheaper to buy the miles up front.
Anrosphynx
Post by Anrosphynx »
I have a vibe GT with the same engine. It currently has 118k on it. no problems at all.
