Antifreeze leaking
bull77
Antifreeze leaking
Post by bull77 »
Just got back from having a car wash and now I'm leaking fluid. Vibe was just serviced (semi, fluids flush) and there wasn't a leak when I was vacumning earlier.I'm thinking a hose may have come loose with the spray. I don't see any damage but the fluid is leaking from both sides of the radiator. Should I fill it up again (currently just above 'Low') and buy some leak stoppage fluid or should I wait and bring it to the dealer?!
18stars
Post by 18stars »
If you cannot locate the leak I would take it to the dealer and would not try any stop leak products.
__________________________________Current Vibe: 2007 Stealth
djb383
Re: Antifreeze leaking (bull77)
Post by djb383 »
Make sure the radiator drain plug is tight/not leaking. The best way to check for full coolant is to (WITH ENGINE COLD) remove the radiator cap and check. If low, add to radiator and overflow bottle, if it's also low.
northvibe
Post by northvibe »
If I were you, Id try to locate the leak myself...If I couldnt find the source, add more to make it till you can have the dealer look at it (under warranty right?) I wouldnt add any of those stop leak things, specially if you have a car under warranty
bull77
Post by bull77 »
Update: So I monitored the levels for the next week and the temp hasn't risen higher than half. I also haven't seen any more leaks Don't know what happened, but I'll probably be in the garage sooner than later with the fan issue, so I can mention it then
WaveAction
Post by WaveAction »
it coulda been just some excess fluid that was on the radiator or the actual structure that holds it up and the wash just drained it off and thats when u noticed it..
bull77
Post by bull77 »
That was probably it - I guess I freaked when I still saw it dripping 20 minutes later
