engine noise on 08 vibe
carl442
Post by carl442 »
i know these lil' 4 bangers make noise and it is normal. is there any thing u can do besides pump up the monsoon? thanx carl442
northvibe
Post by northvibe »
well for the front it may be sorta hard, because of the dash and firewall but theres that noise deadening mat stuff for audio thigns. Dynamat? Bluecrush did a lot of that mat placement in his car I know and it helped some. He said a lot of the noise came from the rear end too...he should post up soon..
BlueCrush
Re: engine noise on 08 vibe (carl442)
Post by BlueCrush »
Yeah, theres not much you can do for the engine noise itself. I went from a CAI to a SRI to the stock airbox with an K&N and then to the OEM filter. (That probably helped the most with intake noise). I also used FatMat on the floor/cargo area and foil-backed foam on the doors which helped with road and exhaust noise. The noise from the rear that NV is referring to is from my custom exhaust.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
northvibe
Post by northvibe »
everyone needs exhuast though haha. For the engine... yeah all I can think of is 3m double sided tape for the ratting plastic A pillars...mine go nuts sometimes....
