to improve a/c performance=??
jamesmetairie
Post by jamesmetairie »
i noticed something in a engine photo of a "vibe of the month" car belonging to = "damronjr". question = is that some piping insulation around one of the a/c pipes ?i,m hoping to get lower temps outta the vents.it,s hot down here in new orleans and sometimes for hurricane evacuations it takes 10 hours to go 90 miles.
WaveAction
Post by WaveAction »
easy stuff..just go to a hardware store and get the insulated piping stuff..it's almost like a dense foam for house hold pipes..which does the same thing..probably cost ya $10-15 for 1 piece..if that
kevera
Re: (WaveAction)
Post by kevera »
Just get the high temp stuff from home depot.
northvibe
Post by northvibe »
yeah just make sure it handles hot temp, mine was fire retardant as well. Then get some zip ties and zip it on. I think its 1/2inch for the big pipe and 3/4inch for the smaller part...
MarkM04
Post by MarkM04 »
Did it actually make a difference?
djb383
Re: to improve a/c performance=?? (jamesmetairie)
Post by djb383 »
It did absolutely nothing for me. Make sure the condenser is NOT full of bugs and have the refrigerant checked for proper pressure. A/C line insulation« » 5:04 PM 7/8/2007 Reply EditSupposedly, insulating the low pressure A/C line will give better cooling. Here is my observation and how I did my test. First thing I did was to cut the correct lengths of insulation so I could could install them as quickly as possible after making my baseline test in order to complete the "insulation installed" test under the same driving conditions (ambient temp and humidity). Each test run covered a 11.1 mile loop, mostly at 70 mph, thermometer in dash vent just to the right of steering wheel. I tested my thermometer in a glass of ice water - it indicated 32F.First, or baseline, test: Completely stock, no insulation, Weather Channel showed 25% humidity, left house at 3:20 pm, A/C on max, dash temp showed 97F, returned to house at 3:32 pm.Lowest observed temp was 38F - No InsulationSecond test: Insulation installed, Weather Channel showed 24% humidity, left house at 3:41 pm, A/C again on max, dash temp still showed 97F, returned to house at 3:53 pm.Lowest observed temp was 38F - Insulation InstalledMYTH BUSTED! Let the flaming begin. LOL
Sublimewind
Re: to improve a/c performance=?? (djb383)
Post by Sublimewind »
Quote, originally posted by djb383 »Lowest observed temp was 38F - Insulation InstalledMYTH BUSTED! Let the flaming begin. LOLYou are quite the Mythbuster there djb383 and for that i give you this.....
djb383
Re: to improve a/c performance=?? (Sublimewind)
Post by djb383 »
Wow, the flaming did begin 'cause she's really hot. Where did that 3rd thumb come from?
Sublimewind
Quote, originally posted by djb383 »Wow, the flaming did begin 'cause she's really hot. Where did that 3rd thumb come from? Who knows and who cares, i don't see no thumbs...
northvibe
Post by northvibe »
some members had it help...i guess some didnt...we like to ignore those ones though hahah. It helped for me! thats all that matters.
Fingers
Post by Fingers »
The mind is a powerful source of psychological trickery. If you want to improve your AC performance, purge your R134a, and fill it with a propane-based refrigerant such as R12A (not to be confused with R12 - freeon). Duracool or Redtek offer this product. A third of the same volume of refrigerant will amount to the same head pressures. And the cooling performance is phenominal.
djb383
Re: (Fingers)
Post by djb383 »
Is that stuff available to the general public or do have to have a permit/license to buy it?
northvibe
Post by northvibe »
um +1 to that, cuz I need it colder...i want icicles on my face when i drive with the AC on.... im assuming the liquid recycling center does AC freon/liquid crap too? :s and by a third..do you not fill it up totally? you only need a third of what use to be used..or you mean a 1/3 of the new stuff is as good as what the old stuff was full so if you do a full of the new its amazingly colder?
