So, my passenger side headlight is getting some moisture...haven't really taken the time to take it apart and see where the leak is but I do know that it isn't filling with water....which is a good thing. Called the dealership to see how much it would cost to get a new one.$421.50.....each!!!!! (removed)? I couldn't believe that....so, needless to say, I'm finding one somewhere else other than a dealership.
2003 Pontiac VibeSalsaPower PackageSports PackageK&N Air Filter
That's in canidan, so it's really like 42.15 here in Emerica.... lolI kid, I kid....... WoW, that hurts to think about it..... Pull it out, take the bulbs out, bake in the oven on the lowest setting possible till dry, and seal with silicone, replace... almost free...
Quote, originally posted by Big_Red »So, my passenger side headlight is getting some moisture...haven't really taken the time to take it apart and see where the leak is but I do know that it isn't filling with water....which is a good thing. Called the dealership to see how much it would cost to get a new one.$421.50.....each!!!!! (removed)? I couldn't believe that....so, needless to say, I'm finding one somewhere else other than a stealership.Fisked for jou...
good find sunny..i work at a gm dealer and even i get ripped off..i got a quote for the rear panel in the cargo area that has the sub hole..was like $630cdn..i was like..and thats with my discount? and he said yes..lol..
while i know there are probably a million junk yards around, i would try the one that's north of steeles on 5th or 6th line just north of Milton (drive up 6th and if you don't see it by 5 Side Road, then turn left to get to 5th line and drive south and it'll be there). They seem to have quite a selection and my friend mentioned that there were some vibes in their 'lot' not too long ago.
Get a heat gun and peel them apart. Clean out the old glue and redo with some clear RTV silicone. Total cost $6, make it $30 if you have to buy a heat gun.
I think these headlights are VENTED.... I recently washed mine and had what looked like condensation inside both lights and after a few hours it was gone.... Something to look at...??
