spark plug gapping??!!
lordsaber
Post by lordsaber »
lol this is sad but as of 2 days ago it came to my attention that spark plugs need to be gapped to get peak performance, or so i heard.... if so, whats the size gap i need, or where can i go to find it. also what point would it serve? i have a standard 5 spd base vibe 2004. please advise. thanks
BlueCrush
Re: spark plug gapping??!! (lordsaber)
Post by BlueCrush »
All spark plugs for the Vibe should already be pre-gapped. There should be no need to adjust them.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
if you want to check/set the gap, the 2004 Vibe owner's manual, ( free download at http://forums.genvibe.com/zerothread?id=1010 ) page 5-102 says the spark plug gap is 0.043 inch (1.1 mm) for both tne base and GT engines
northvibe
Post by northvibe »
for sure the iridium plugs come pregapped, do not try to gap those it will ruin the prong things.
drunkenmaxx
Re: (northvibe)
Post by drunkenmaxx »
Quote, originally posted by northvibe » prong things.can someone explain that without the technobabble?
kcorona
Re: (drunkenmaxx)
Post by kcorona »
prong things = ground electrode
'04 Shadow Monotone Base AT power pkg., + FIAMM low note horn, GM exhaust tip, GM splash guards x 4
Sublimewind
Re: (kcorona)
Post by Sublimewind »
Quote, originally posted by kcorona »prong things = ground electrodeIt's not the ground electrode you have to worry about with them, but the iridum portion it's self, it's brittle and easy to bend break such a fine electrode... Quote » also what point would it serve?Gapping sets the distance between the electrodes, as the pressure in the cylinder rises the resistance goes up, as the temp goes up resistance ALSO goes up... the ignition system is designed to throw a spark across a certin distance (gap) if the gap is to large, misfiring can happen, if it is to small, the spark may be shielded but the ground electrode causeing ununiform burning of the mixture.
mathteacher'04vibe
Post by mathteacher'04vibe »
I know that Bosch plat 4's are not supposed to be gapped. However, it is possible to gap other iridiums. I gapped my NGK's and I am glad I did--they were way off the 0.043 recommendation!BTW, all cars have a sticker on/under the hood that gives the spark plug gap info--it often gives the engine size, gap info, and sometimes even the belt routing.
'04 Vibe 1.8VVT-i, K&N Typhoon S/R, Fullboar muffler w/3.5" resonator tip. Sony CDX-GT500 h/u + Fosgate mono amp w/2 10" woofers & cap. Tinted side rear windows, SilverStar headlights and Cool Blue fogs. DC Sports Headers. 2.5" stainless pipe from stock resonator to muffler. Limited 903's (17x7.5) Gunmetal Gray with 225/45/R17 Strata tires. Link to my photobucket videos: http://s100.photobucket.com/al...ideos/
kevera
Re: spark plug gapping??!! (mathteacher'04vibe)
Post by kevera »
I agree,I always check mine too.The NGK's I got when I installed the s/c were off by a bit .So,just be careful if you have to adjust the gap.
Whelan
Re: spark plug gapping??!! (kevera)
Post by Whelan »
I never understood the point of the Bosch +2 or +4. I had a set of +2 and never saw any difference in anything.
2012 GLI Autobahn 6MT
Sublimewind
Re: spark plug gapping??!! (Whelan)
Quote, originally posted by Whelan »I never understood the point of the Bosch +2 or +4. I had a set of +2 and never saw any difference in anything.I have a mechanic friend He drag races snowmobiles, that wouldn't put Bosch ANYTHING in the sled of the guy he was about the race... He says they DO suck that bad... NGK...... NGK...
