Want to get a modest HP increase from a 2004 Matrix XR 4WD
gregbailey88
Post by gregbailey88 »
My wife has an 04 Matrix XR 4WD. Warranty is up and I would like to tweak it. It is somewhat underpowered at present.What do you suggest that I can do to get a 10 - 20% power increase without making the car too loud or breaking the bank.Apprecite your help.Greg
BlueCrush
Re: Want to get a modest HP increase from a 2004 Matrix XR 4WD (gregbailey88)
Post by BlueCrush »
This should get you on the right path:http://forums.genvibe.com/zero...24144
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
keithvibe
Post by keithvibe »
welcome! Fact is there isn't very much you can do with out breaking the bankLook at http://forums.genvibe.com/zerothread?id=22889IF there is anyone who knows what you can get out of an AWD it's him... To cover the basics... there is a cold air intake you can get http://www.cosmoracing.com/pro...=1258If you go that route most replace the filer that is supplied with an AEM dryflow filter.There isn't an aftermarket exhaust for the AWD only choice there is customAgain, welcome and if you might have any other questions you can use the search function to find most anything your looking for... and if not... post a new thread and someone will be more than happy to help if they can.HAHAHABeat me too it Brian... ^^^^the man in question LOL
BlueCrush
Re: Want to get a modest HP increase from a 2004 Matrix XR 4WD (keithvibe)
Post by BlueCrush »
Thanks, Keith. I can suggest some other things but they will definitely made your car louder. (ie: hollow out pre-cat, full 2-1/4" exhaust w/highflow cat, resonator & muffler (or two mufflers)).An intake will also make your car louder. If you want to keep it quieter try taking off the airbox snorkel that goes from the bottom front of the airbox to the front grille. If you do this also get a K&N drop in filter Part #33-2252.
My Fleet:
