having a very annoying problem.
injun_josh
Post by injun_josh »
as of late, everytime i put gas in, the gas nozzle clicks and stops like it is full of gas, even if the car is empty. it has even over flowed once. it takes me like 5 minutes to put in 20 bucks worth cause i have to constantly wait for the gas to drain into the tank. anybody ever had this prob? im gonna get under the car this weekend .
ToolGuy
Re: having a very annoying problem. (injun_josh)
Post by ToolGuy »
I feel when this happens, it is the pump/nozzle not the car itself. If I am understanding you correctly...Try, if you have not, pulling the nozzle away from the filler neck a little so the fumes can escape easier. You may have to really watch so it does not over flow on you though when you do this.
Sublimewind
Post by Sublimewind »
Sounds to me like the vant in the tank might not be working correctly... Heck, there might not even be a vent... so i donno... You guys have the same avatar pic... i had to do a double take to see if you wern't answering your own question...
Mavrik
Re: (Sublimewind)
Post by Mavrik »
either a pump issue or filler neck issue. Try another pump and see what happens, that will determine if its the car and not the gas station.Now by your description though it seems its been doing this for a while? then if so probably is the car.
I remembered a thread, and it took a bit to find the right things to search on.Check out http://forums.genvibe.com/zerothread?id=5204 and http://forums.genvibe.com/zerothread?id=5686
