That Nasty Egg Smell
rockinvibe
Post by rockinvibe »
Has anyone else encountered that nasty egg smell, after you first drive the car for a couple of miles. I was blaming the guy I take to work, however he wasn't in the car yesterday, and I smelled it again. My guess is the convertor, but I wanted to know if anyone else smelled it too ? Steve
Vibe Rater
Re: That Nasty Egg Smell (rockinvibe)
Post by Vibe Rater »
I would just keep blaming the guy you take to work. Tell him he has ruined your new car by farting on the seat. Tell him he needs to see a doctor. He needs to know that eating so many pickled eggs will aid in raising his bad cholesteral, which can lead to heart disease. The little pickled sausages in the big jar beside the pickled eggs aren't much better.
csjrishere
Re: That Nasty Egg Smell (silverawd26)
Post by csjrishere »
I get the same smell and I buy my gas at BP.
Monotone Salsa, Moon & Tunes w/6 disc in dash, 16" Wheels
millster
Re: That Nasty Egg Smell (csjrishere)
Post by millster »
quote:I get the same smell and I buy my gas at BP.Quite honestly, I would avoid BP. I had no end to trouble with my Saturn (not that that thing wasn't trouble to being with, but BP really upset it) when I was using BP gas. Like SilverAWD, I've had the best luck with Mobil.
-Millster-
2006 Toyota Matrix XR
1995 Saab 9000CSE 2.3T
Flip-Side
Post by Flip-Side »
quote:I get the same smell and I buy my gas at BP.Hmmm...I always though BP was good gas. Oh well. You cant go wrong with Mobil, Shell, Amoco, Texaco, and Chevron. They are all clean burning and dont have alcohol added to them, so they have always given me good performance. Auto makers in Detroit transport Chevron fuel long distances because of the quality and help it gives in passing emmisions tests. Texaco and Chevron are the same company.
m4VibeGT
Re: That Nasty Egg Smell (Flip-Side)
Post by m4VibeGT »
FYI. Amoco was bought by BP. So all Amoco stations in my area are now switching to the green and yellow "BP" signs.
2003 Vibe GT Satellite MonotoneTRD CAI, Magnaflow Exhaust, Unichip
vibe owner
Re: That Nasty Egg Smell (m4VibeGT)
Post by vibe owner »
Unless you're breathing exhaust, the gasoline has nothing to do with the smell. There is a thread at matrixvibe.org that claims there is a Technical Service Bulletin about rotten egg smell, but the TSB itself isn't posted yet.
vibe owner
The cat could run hot because of a fuel choice, but there still has to be something outside the converter that smells when it gets hot. I'm guessing some part of the exhaust is touching some undercoated part, probably only briefly when the engine torque bends stuff around when you start in first gear. I'd look for tight clearances where the exhaust pipe passes under the car.
millster
Re: That Nasty Egg Smell (vibe owner)
Post by millster »
quote:Unless you're breathing exhaust, the gasoline has nothing to do with the smell. There is a thread at matrixvibe.org that claims there is a Technical Service Bulletin about rotten egg smell, but the TSB itself isn't posted yet.Do you mean MatrixVibe.net? MatrixVibe.org is but a memory now. The TSB states that if you are not seeing a CEL then switch your fuel. Yes, a failing catalytic converter can smell, but more than likely it's the fuel. Refined petroleum contains a certain amount of sulfur and different brands of petrol contain different amounts of sulfur. This excess sulfur is then burned off in the cat and there's your spoiled egg smell.
-Millster-
millster
Post by millster »
No problem. My Saturn dealer and I went round and round on this one. Finally, he showed me the info and told me to stay away from BP. Once I went to Mobil the smell went away.
-Millster-
millster
Post by millster »
No, driving it hard won't help. One thing I forgot to mention is that different brands also differ by state and region. Just because one brand is bad say on the east coast doesn't mean it will be bad on the west coast. To stick with out BP example, they market a low-sulfur product to Colorado, California and Washington, to name a few. This is done to meet with emissions standards and remain competitive in those markets. However, to save the cost of the extra refinement, states with no or lesser restrictions are sold a different product.
-Millster-
vibe owner
Re: That Nasty Egg Smell (millster)
Sorry millster and silver, but I'm still not buying it. Unless the smell is only noticed while standing still? If you're driving, any smell coming out of your exhaust will never get inside your car.
millster
Post by millster »
quote:Sorry millster and silver, but I'm still not buying it. Unless the smell is only noticed while standing still? If you're driving, any smell coming out of your exhaust will never get inside your car. I've never noticed a smell from my Vibe, only my past vehicles and it can be smelled while driving. As I stated earlier it was only an issue until I changed the brand of fuel I was buying. The only times I've smelled anything exhaust related in the Vibe was driving behind a poorly tuned vehicle with my climate control fan running. It is possible there is a problem, though you should have some other indication than just a smell. If you suspect there really is an issue, contact your dealer and keep us posted on what they find.
-Millster-
Lorin
Post by Lorin »
quote:This excess sulfur is then burned off in the cat and there's your spoiled egg smell. H2S is the classic rotten egg gas - other sulfurous compounds can smell similar but even stronger. You only need 1-2 parts per million of H2S before you can smell it - that's not very much! Change to a gas with less sulfur and you solve the problem. That is, as long as the source wasn't the passenger f@rting in your seat! Refer to the waterproof seat cover discussion in the "Interior" forum for 'extreme' cases!
Lorin2003 Pontiac Vibe GT, Neptune-mono, moons & tunes, power package, side impact airbags, rear seat covers, bumper protector, cargo mat.Mods installed: TRD exhaust, TRD stb, Mods removed: TRD CAI - annoyed by CEL
MadBill
Post by MadBill »
"And yes, you can smell fumes sometimes when you are inside your vehicle, it can happen."[/QUOTE]I'm with silverawd26 on this one! You can definietly get a whiff of your own exhaust from time to time! Also, a number of cars have had similar problems over the years (some recent Fords for one) I believe certain formulations of the precious metals in the converter make it more efficent at converting the high sulphur content in some fuels to a noxious compound named hydrogen sulphide ("rotten egg gas")I think I heard that the Platinum/Paladium/Rhodium mix in the Vibe's converter was revised, possibly late last summer, for this reason. About all an owner can do is to find a low-sulphur brand of fuel and stick with it. (You could try complaining to the dealer, but he will likey blame the fuel.) For what it's worth, my base Vibe, built in November '02, has never stunk me out, even with Esso, the highest sulphur fuel in Canada.
philndz
Post by philndz »
anyone drive w/ the rear glass open....hehe...i do on local drives. under 40mph on nice days.....give it some gas and u'll get a whiff.i wouldnt do this w/o all your windows and the moonroof open though b/c then u need to worry about carbon monoxide and what not....so be careful
philndz
Post by philndz »
mine must have more pressure in the shocks than yours then b/c it doesnt move up there at all....no matter what i drive over.i have a 10-15 minute drive back from local state park and after mountain biking on a warm day its awesome to have 6 open air holes in the car....especially when ive got a few stinky peeps ridin in it....!
philndz
Post by philndz »
most of our suburban roads are well paved...and the vibe simply refuses to take to the trails like the old jeep! <<darn!!
philndz
Post by philndz »
gas saver?............whats it help?
msmyer
Post by msmyer »
Check this out .... http://forums.genvibe.com/zerothread?id=1026 I have around 9,200 miles on mine now and i don't have that problem anymore!
‘03 Vibe with 317k and still going.............................
Other Mods: Sony X-Plod Headunit & Reflective White GVC decalMy Car at Cardomain.com... http://www.cardomain.com/id/msmyer
good vibes
Post by good vibes »
I also have smelled rotten eggs usually when I back into my "parking spot" at home. I get my gas from various stations. And I smell it most of the time. I'm guessing it is just the cat eating the easter bunny!
My Car: 2003 Vibe AWD Shadow/Graphite My Options: Vibe Rubber Floor Mats, Vibe Back Seat Pouches w/ First Aid Kit My Extras: Anti-Fatigue Mat Cut To Fit, PIAA H4 Headlights, grafixwerks stuff, yakima bike blocks, roof rack with land shark for my kayak, and loadwarrior, hella tripple tone air horns (wanna hear a loud horn? get these!) Rockford Fosgate fanatic 6 1/2".
good vibes
I could do that. It's just a matter of either driving into Jersey, about 15 minutes and getting less expensive gas or staying here and paying another 10 cents per gallon. Hmm what would you do? I think I'll give my money to Jersey!
Sputnik
Post by Sputnik »
Here's another earlier thread on the same topic...http://forums.genvibe.com/zerothread?id=1189Might give ya more information on the smell.
GenVibe Global Moderator
good vibes
Re: That Nasty Egg Smell (Sputnik)
See the thing that has me wondering is why this waasn't an issue with my last vehicle 1991 Nissan Pickup or any of my parents cars, '01 civic, '02 S-10 ZR2, '97 Yukon. None of them have this problem and we all use different gas stations all the time. I am thinking it could be an issue with our cars.
coratz
Post by coratz »
if it was a major isuse gm would have issued a tsb by now. a recall on 2 cats on the vibe would cost a heck off a lot of money!!. i dont see it happening. i think the cats in canada have like an 8 year warenty. just let your car warm up before flooring it.
good vibes
Re: That Nasty Egg Smell (coratz)
It is definately a Cat Issue you should complaint o your dealer and be a pest about having them replace it. It is NOT NORMAL even if everyone does smell it. Bad exhaust is NOT A GOOD THING.
coratz
Re: That Nasty Egg Smell (good vibes)
Post by coratz »
that smell is the cats actually doing their job.
NovaResource
Post by NovaResource »
I usually only get the smell if I drive it hard before the car fully warms up. Once the cat is hot the smell goes away.
good vibes
I talked to my mom about it (she works at a Pontiac dealer in Jersey and is having the service manager look into it for us. I'll keep you posted on what is said.
meathead333
Post by meathead333 »
wow, that funny, i too have smelt that egg/sulfer smell a few times. never thought it was me. maybe ill have to shuv a tic-tac up my cars tail pipe from time to time.
My myspace.com profile My 73' Bronco Cardomain page
good vibes
he he he so am I.
Fredf
Post by Fredf »
Thanks...I'll try Mobil
viberations
Post by viberations »
rockin, i work at pontiac dealership, we have this all the time, and most of the cause the chemicals in the gas, 5% methanol on pumpsis most likely the cause,and there really is no way to get rid of it sincemost companys use it in there fuel. i have 28k on my vibe and stillget the smell, it builds up in the catalyst and lets out at certin timesreally unavoidable
PJV TOYOTA DEALER ROCHESTER N.Y
Re: That Nasty Egg Smell (viberations)
For me the problem isn't so much that the exhaust smells bad, it's that people can smell it inside their cars. I've been lucky and haven't had this problem, probably because I've been buying my gas at the same station, and maybe their brand is less likely to stink. Don't know, maybe just luck.I noticed an extra sound when I shut my hatch, and after looking around I found that there are vents in the back on both sides. These are a black plastic frame, and have some sort of rubberized fabric flaps that normally hang down to keep them closed. I guess they are there to provide a pressure release when you shut the doors or the hatch, and maybe also to provide somewhere for the air to go when you've got the heater/AC fan on. I wonder if people who have constant recurring problems with the "rotten egg" smell might have a problem with these vents sealing. Also, after seeing these, I'll make sure that I have lots of positive ventilation going on, to keep from drawing air in through them.There's also a clear blue plastic hose on both sides, and I can see on the underside where hose comes through, not connected to anything. Must be some kind of drain. I can't see where it goes on the inside. I've got the M&T, so it may be for the moonroof, can't tell. Anybody know what the hoses are for?
viberations
Re: That Nasty Egg Smell (joatmon)
joat nice work,
quote:There's also a clear blue plastic hose on both sides, and I can see on the underside where hose comes through, not connected to anything. Must be some kind of drain. I can't see where it goes on the inside. I've got the M&T, so it may be for the moonroof, can't tell. Anybody know what the hoses are for? Found a service manual and saw that the hoses are drains for the sunroof.
