I bought a sub woofer that is out of an 06 Vibe on eBay. It has a 4 pin connector.....see photo. Does anyone know the hookup configuration? The label on the sub says 2+2 ohms 50+50 watts. Does this unit have it's own amp built into it? In that case two of the leads would be for power, and the other two leads would be for line lever audio. If there is no amp, then it would just hookup to the LR and RR speaker leads. I have an 04 Vibe with the 6 speaker system and would like to add the sub to give me the 7 speaker configuration.Thank you for any help with this.........
