Wiring my new Stebel Nautilus Horn?
Vibetastic
Post by Vibetastic »
Here are the instructionshttp://www.bikerhiway.com/inst...n.pdfDoes anyone know how I would wire this to my Vibe. There is only one wire going to the stock horn, not 2 like in the instructions.
Proud owner of a 2005 Vibe. Moon & TunesAlloy wheelsOnStar Lava with Slate interior
zionzr2
Post by zionzr2 »
since the horn is mounted to the frame, the second or ground wire is not needed in most cases.if your horn is equiped with a second wire simply ground it to the frame.
Vibetastic
Re: (zionzr2)
So the ground wire that would go to a 2 wire horn would go from the relay to the chassis since the original horn only has one wire?
