Coolant Loss
04BlkVibe
Coolant Loss
Post by 04BlkVibe »
Alright,..I know there is postings out there about coolant loss. I was wondering if anyone on this site actually kept a good eye on it. Would you know what's a reasonable amount of coolant loss?
2004 Abyss Vibe 5Spd Sport Appearance Package (Factory spoilers and ground effect)Sports Package (16" Wheels and Sunroof)Power Package, Safety Package (ABS and Side Air Bags)Monotone, 30% Tint all aroundNon Factory Option: Backup Sensor, Alpine MP3 Player, Autodimming Mirror, 17" Matrix RimsCome see it all at: http://members.cardomain.com/04blkvibe
JohnC
Re: Coolant Loss (04BlkVibe)
Post by JohnC »
I kept a very close eye on mine by marking the level in the resevoir after it was completly cool. It took a long time to figure out where my seapage was coming from but finally it was apparent that the water pump shaft had a very small leak. Here is a link to that discussion.http://forums.genvibe.com/zerothread?id=23818
04BlkVibe
Post by 04BlkVibe »
Thanks. I don't recall seeing anything. Perhaps i'll take some pictures tomorrow.
MarkM04
Re: (04BlkVibe)
Post by MarkM04 »
I'd get a uses oil analysis done asap. If coolant is getting into your oil, and can do a lot of damage, in little time.
Vivid_Art
Re: (MarkM04)
Post by Vivid_Art »
Or you can just check the oil and see if its turned intoa creamy white substance, thats what happends when coolant mixes with oil. Then you know somethins wrong!Quote, originally posted by MarkM04 »I'd get a uses oil analysis done asap. If coolant is getting into your oil, and can do a lot of damage, in little time.
djb383
Post by djb383 »
Quote, originally posted by 04BlkVibe » Would you know what's a reasonable amount of coolant loss?None. It is a closed system. If the level is dropping any, you have a leak.
Petrucci914
Re: Coolant Loss (djb383)
Post by Petrucci914 »
Check MatrixOwners site. I saw something on this and it involved a bad Thermostat that was leaking coolant vapors.
jasonvibe
Post by jasonvibe »
Mine in the 1st year(12k) the level went down when cold about 1.5" . This was about 6oz. I figure it's from the res. being right behind the radiator. The heat will cause some evaporation. Any car with the reservoir by a heat source will go down some. Just nothing you would notice day to day. I also always smell coolant right at the radiator cap with my nose inches away. These us an odd inside cap design . I replaced the cap and still smell it when hot. But no sign of leaks.
