petrucci, i posted this response to your thread on matrixowners...Toyota motor mounts, especially front and rear mounts (the torque mounts), seem to have a lot of "give" for comfort. Not the best thing for performance. A lot of Matrix owners w/ manual trans have installed Energy Suspension polyurethane motor mount inserts to fix the problem. They make the motor "rock solid" at the cost of increased vibration. Problem is, they're not available for Matrix/Vibe with auto trans.You have a couple options, though:What you might want to do is strengthen your front and rear mounts, yourself, by filling the nooks & crannies in the stock mounts with 3M Auto Glass Urethane Windshield Adhesive. I've seen a couple DIY articles in books & magazines using this product with great results. Basically, what you do is remove the stock front & rear motor mounts, tape the backside shut, fill one side of the mount w/ urethane, let it harden, and then fill the other side and let it harden. Install the mounts and your done. As was mentioned, though, the rear mount is a real b**** to remove.Here's a link to the 3M urethane product:
http://solutions.3m.com/wps/po...ndlerThere's also a guy on eBay selling do-it-yourself urethane kits for filling front & rear mounts on cars that don't have ready-made motor mount inserts. They cost $30-$35 and come in three choices of durometer specs, depending on how much "stiffening" you're after. I'm thinking, maybe the 60-durometer kit is enough for you. Click on his "Universal Motor Mount Inserts" link for a good tutorial on how to do it.
http://cgi.ebay.com/ebaymotors...83196
